Am I missing something......
Posted: Tue Sep 12, 2006 4:54 pm
by askipd
I have downloaded papagayo but it is not associated with any program. What do I open it with to load the program. I am very (very) new at this.
Thanks,
Skip
Posted: Tue Sep 12, 2006 10:32 pm
by nassosy
I assume you downloaded the source code version
and you don't have Python and wxPython installed on your system,
which i imagine is a windows pc.
Download Python from here (v2.4 is a good choice):
htt://
www.python.org
and wxPython for the Python version above you installed from here:
http://www.wxpython.org
after you install both (first python, then wxpython)
open a command line window
go to the directory you installed 'papagayo' (with "cd directory")
and type "python papagayo.py"
it should start the program in a few seconds
Since you are new to this, it would be wiser to download the binary version of the program.
BTW you should also check out "PapagayoMOD" a modified version
of papagayo which has alot more features.
Binary
Posted: Fri Sep 15, 2006 6:17 pm
by askipd
I downloaded the binary version (the one I would rather use) I guess my question is how do you run the binary version. What program do you associate it with to get it to run?
Posted: Sat Sep 16, 2006 12:13 am
by nassosy
Unrar the contents of the archive to a folder (ex: c:\papagayoMod\)
There you will find a file called "papagayo.exe"
You either double-click on it with your mouse from the explorer window,
or select it and press the 'Enter' key.
Both do the same thing, they start the application.
After a few seconds the PapagayoMOD window should appear.
If nothing happens, check the folder for a file called "papagayo.exe.log"
It is the error log
Open it in the notepad and post its contents in this forum.
