Switch Action
Posted: Sun Oct 31, 2004 7:42 pm
by Sine
Can we use switch layers for actions?
It doesn't seem to work now. I make some hand gestures in a switch layer and animated an action. But referencing the action in the main timeline does not work.
Posted: Mon Nov 01, 2004 9:57 am
by WillBellJr
That's a great idea - I'd love to see that implemented!
I'd like to know if actions are stretchable - being able to drag the length of an action thereby scaling it to fit a particular needed length of time?
-Will
Posted: Mon Nov 01, 2004 10:41 am
by Lost Marble
So yes, there does seem to be a bug in switch channels and actions. A switch action cannot be inserted by reference into the main timeline. However, it does seem to work if you insert the action as a copy instead. So that's the workaround until we get the issue fixed.
As far as stretching an action, you can't do that now. However, if you insert an action as a copy, not by reference, then it just becomes regular keyframes in the main timeline, and you can edit those however you wish.
Posted: Mon Nov 01, 2004 11:33 am
by WillBellJr
Thanks for the reply - yes I understand about copying and then modifying the keyframes.
I posted it as a wish item because it would be a nice simple (and logical) operation to just drag the ends of the action to fit them where needed on the timeline.
Thanks again for such a wonderful program!
-Will
Posted: Mon Nov 01, 2004 4:36 pm
by spasmodic_cheese
yeh i came across this too the ohter day... would be very helpful!
