How to recover windows/panels that are off screen?
Posted: Tue May 19, 2026 9:47 pm
After switching a monitor set-up, I found I was not able to access pop-up windows (project settings, colour picker, Import layers, etc). It turned out that these items are opening up off-screen, and once open, the program just gives you an error noise when you attempt to do anything (until I hit 'Esc' key to close the off-screen window).
I was able to switch back to the old set-up to be able to access and move those windows back into view, but it would be great if there was a feature that would let you select and move offscreen windows, or to 'call' them back to your main screen.
Please let me know if there is a better solution that swapping my active monitors in order to access off screen windows.
