Moho Fetal Error loading Application
Panha
Post by Panha »
Hi everyone! I really need your urgent help. I was wokring with my Moho 14.4, then trying selecting layer using Alt+right click! The application closed immediately. Wheny trying to open it back, it says fetal error loading the application. I have a really long animation to finish this month. Now it get me the error. I tried unistalling the application, cleaned the AppData, but then reinstalled it back, but it did not help.
https://drive.google.com/file/d/1KcKIwO ... drive_link
Re: Moho Fetal Error loading Application
image is not loading "access denied"
Panha
Post by Panha »
hayasidist wrote: Thu Jan 01, 2026 3:47 am image is not loading "access denied"
sorry for the image. I am very good at sharing on google drive. But here again I believe this link would work. However, now it works! I updated my driver, and reinstall window.
https://drive.google.com/file/d/1KcKIwO ... sp=sharing
glad you got it working -- was that a complete re-install of windows???? (Win 10 or 11?) or did a driver do the trick (if so which one?) (there was a post over on Discord where a user was getting the same error message).
Yes, can you post more details about your solution?
I haven't seen this error either, but I'm curious about your solution.
Panha
Post by Panha »
hayasidist wrote: Thu Jan 01, 2026 4:51 am glad you got it working -- was that a complete re-install of windows???? (Win 10 or 11?) or did a driver do the trick (if so which one?) (there was a post over on Discord where a user was getting the same error message).
I was about to do a complete re-install of window, but I realized that graphical software may struggle with GPU or display drivers, so I updated my drivers (I used my old version of driver for long since it worked well with Moho, and ever since Moho 14.4 released, it was working just fine! But this time (after crushed), I could not open Moho, so I decided to update the driver), but to make sure that it worked! I also went to setting > Fix Problems using window update (There, there is a button says Reinstall now) > it was not a complete re-installing, however, I think it installed the window again by preserving the applications.
Since I was did two thing at the same time, update drivers and reinstalling window (I don't know which one works) however, after doing both, Moho now works again.
Panha
Post by Panha »
Greenlaw wrote: Thu Jan 01, 2026 7:10 am Yes, can you post more details about your solution?
Thank you GreenLaw, I have shared how I worked it out in the above comments (one below your reply), you can check it out. I think becasue of my driver (but it worked just find for long time, just this time, after crushed, it stop working and I need to update the driver)💖.
Panha wrote: Fri Jan 02, 2026 1:23 am
Thank you -- are you able to say exactly which graphics driver? And Win 10 or 11???
Panha
Post by Panha »
hayasidist wrote: Fri Jan 02, 2026 3:55 am
I used Window 11, I have AMD Radeon HD 8600/8700M Version 27.20.1034.6 before the version was 27.20.20912.1002 (I think this one is newer, but it does not work well on my PC, so mybe it was not updated but downgraded), and I also have Intel(R) HD Graphicd 4600 Version 20.19.15.4835.
Panha wrote: Fri Jan 02, 2026 6:39 pm I used Window 11, I have AMD Radeon HD 8600/8700M Version 27.20.1034.6 before the version was 27.20.20912.1002 (I think this one is newer, but it does not work well on my PC, so mybe it was not updated but downgraded), and I also have Intel(R) HD Graphicd 4600 Version 20.19.15.4835.
thank you very helpful.
