soft Moho export / render
J. Baker
Post by J. Baker »
See the two images. In Moho 14.3 the brush looks good. When preview / exported, it is very soft. What to do?
Re: soft Moho export / render
The usual difference between preview/project view and final render? You should always do at least a test render before you decide on any brush.
J. Baker
Post by J. Baker »
In this case I do not see a work around. The final render is destroying the brush detail.
Been using Moho since version 5 and I did take some time off as I was doing other things. Now back at it with Moho 14 and so far every time I touch it, I run into another issue. Hmm...
how big is the rendered word (in pixels)? Have you got AA on?
Hm, I get sharp and crispy results with my brushes. I suspect it's a matter of project dimensions and maybe some other settings?
J. Baker
Post by J. Baker »
It's written in a 720p video setting. I do not see the anti-aliasing setting where it use to be. Did it get moved?
EDIT: Found it in Project Settings. Yes, it is on.
J. Baker
Post by J. Baker »
Here's the file if anyone wants to see.
https://limewire.com/d/THps8#nlP5yY5PSK
This is how it looks at my end. Moho 14.1
J. Baker
Post by J. Baker »
Not seeing an image. Just the word "image."
with the test file, the brush "hairiness" IS lost on render here (14.3 Win 10). I've tried with and without AA; increased the line width; rendered to .png and .jpg -- all similar in losing sharpness
J. Baker
Post by J. Baker »
Yep, that's what I'm seeing. It takes away the effect of the brush. I guess we will have to wait for upper support to see this. It's a little slower these days.
Looks like the render is the same as having GPU caching enabled and a different layer selected.
Since GPU caching is basically turning unselected layers into images, for better workspace performance, it might be equivalent to rendering for image-based brushes.
FWIW, I tried with the same brush but upscaled from 512px square to 2000px square -- same result -- so it doesn't look as though it's a "stamp resolution on render" issue.
Hm, I'd try to downscale instead. Measure the width of the final rendered line in px, then create a sharp brush in exactly that size, and use and test that.
slowtiger wrote: Thu Sep 18, 2025 4:26 am Hm, I'd try to downscale instead. Measure the width of the final rendered line in px, then create a sharp brush in exactly that size, and use and test that.
Genius!
a couple of tests:
here's the re-drawn brush
https://www.mediafire.com/file/dhmxpweo ... S.png/file
