Multiple float dialogs
Posted: Sun Jun 09, 2024 3:02 pm
by MehdiZangenehBar
When I click on dialog with label "1" , all other dialogs will be closed, how we can prevent this?
ScriptName = 'Test_Script'
Test_Script = {}
function Test_Script:OnMouseDown(moho, mouseEvent)
end
function Test_Script:DoLayout(moho, layout)
	for i = 1 , 5 do
		local simple_dialog = LM.GUI.SimpleDialog(tostring(i), {})
		simple_dialog:GetLayout():AddChild(LM.GUI.Button('Button'))
		simple_dialog:DoModeless()
	end
end
Re: Multiple float dialogs
Posted: Sun Jun 09, 2024 4:47 pm
You shouldn't be using doLayout to make modeless dialogs. You can use a button in the tool options (doLayout) instead.
Posted: Mon Jun 10, 2024 2:29 am
by MehdiZangenehBar
synthsin75 wrote: ↑Sun Jun 09, 2024 4:47 pm You shouldn't be using doLayout to make modeless dialogs. You can use a button in the tool options (doLayout) instead.
Well, your answer will not explain the problem, I have to create dialogs using script not any button.
Posted: Mon Jun 10, 2024 2:58 am
by MehdiZangenehBar
funny is that if I close any dialog, it will close next created dialogs.
1 will close 1 .. 5
2 will close 2 .. 5
3 will close 3 .. 5
4 will close 4 .. 5
5 will close 5
Posted: Mon Jun 10, 2024 3:39 pm
If you invoke modeless dialogs from DoLayout, you're asking for instability and crashes. That instance of DoLayout ceases to exist once the tool is changed or entering/leaving frame zero, leaving those dialogs orphaned.
You'd better off using the Run function of a button script to invoke them. But you're welcome to keep testing and prove this for yourself.
Posted: Mon Jun 10, 2024 5:01 pm
by MehdiZangenehBar
In my case that's exactly what I want, close ALL created float dialogs and reopen them on DoLayout. Please take a look at this example:
Test_Script = {}
Test_Script.first_float_dialog = nil
end
function Test_Script:DoLayout(moho, simple_dialog_layout)
	if Test_Script.first_float_dialog ~= nil then
		Test_Script.first_float_dialog.image_text_list:SetSelItem(true)
	end
	for i = 1 , 5 do
		local simple_dialog_layout = simple_dialog:GetLayout()
		simple_dialog.image_text_list = LM.GUI.ImageTextList(100, 100, LM.GUI.MSG_OK)
		simple_dialog_layout:AddChild(simple_dialog.image_text_list)
		if Test_Script.first_float_dialog == nil then Test_Script.first_float_dialog = simple_dialog end
	end
end
This code works perfect, but the crash will accure if we close one of the float dialogs by hitting the X button.
I will consider your advice and caution about the DoLayout, but really there is not ANY functionality to handle this? maybe try catch? or any other tip or trick to prevent the crash?
Posted: Mon Jun 10, 2024 5:15 pm
by MehdiZangenehBar
I just tested with pcall, it seems it will not crash, would you please check this out on your system:
Test_Script = {}
end
		pcall
			function ()
				Test_Script.first_float_dialog.image_text_list:SetSelItem(Test_Script.first_float_dialog.image_text_list:GetItem(0), false)
			end
	end
	for i = 1 , 5 do
		simple_dialog.image_text_list = LM.GUI.ImageTextList(100, 100, LM.GUI.MSG_CANCEL)
		simple_dialog.image_text_list:AddItem("", false)
		simple_dialog_layout:AddChild(simple_dialog.image_text_list, LM.GUI.ALIGN_LEFT, 0)
	end
end
Posted: Mon Jun 10, 2024 5:33 pm
by MehdiZangenehBar
OK, you right!
it will crash randomly...
I should change my method to the button.
Thanks for your explantion.
