select shape in a different layer?
Posted: Fri Apr 26, 2024 1:35 pm
by Nicohk92
I may be wrong but I sort of remember from a long time ago that there was a shortcut to select a shape (Q) located in a different layer than the one selected. Not sure if it's a false memory or if there is indeed such modifier key. Would be a great time saver to not to have to select the layer beforehand each time.
Re: select shape in a different layer?
Posted: Fri Apr 26, 2024 2:24 pm
Alt+R Click on a visible shape selects the shape and its layer.
Posted: Fri Apr 26, 2024 2:31 pm
I should clarify:
I'm assuming you have the Select Shape tool selected. (Q selects the Select Shape tool.)
The Shortcut Alt+R Click actually selects the layer the shape belongs to. Once the layer is selected, click again without the Alt+R Click modifier to select the shape.
BTW, Alt+R Click works with any tool, not just the Select Shape tool.
Posted: Fri Apr 26, 2024 2:40 pm
Or is your intention to select multiple shapes across layers? For that, you'll want to use SimplSam's Multi-layer Transform tool.
Also, a great companion to this tool is A.Evseeva's Multi-layer Magnet
Posted: Fri Apr 26, 2024 3:32 pm
by Nicohk92
Thanks a lot Greenlaw, it was ALt+R, and I didn't realize it works with other tools. That's pretty great.
