reverse curve direction?
Posted: Tue Apr 16, 2024 11:08 am
by martin_mrt
Hey there!
Quick question: is it possible in MOHO to reverse the direction of a Curve?
I came across that issue today when working with assymetrical brushes where it would be (or is?) very helpful.
thanks in advance for any answer!
Re: reverse curve direction?
Posted: Tue Apr 16, 2024 2:26 pm
I'm not aware of a way to reverse a curve's direction.
What I've done in the past was duplicate a brush's artwork and edit the brush art. For example, if the brush were an arrow, I would rotate the art 180 degrees to change its direction.
If this is a native Moho brush, there are additional considerations.
You will want to copy the brush file or folder that you need to edit from the program directory here...
C:\Program Files\Moho\Moho 14\Resources\Support\Common\Brushes
...and place the copy in your Custom Content Folder. Then, you need to rename the file or folder so it appears as an alternative brush and not a replacement. Now you can change the copy's artwork.
After editing the brush, press Ctrl+Shift+Alt+L, and the alternative brush should appear at the end of the Brushes window.
Posted: Tue Apr 16, 2024 2:31 pm
Even though it's rare when I've had to do the above, it makes me think we should have Mirror and Rotate options in the Brushes window.
Posted: Mon Apr 29, 2024 7:01 am
by martin_mrt
Hey Greenlaw,
Thanks for the Reply!
That is the way i went for now.
I agree that a flipping option would be super for the Brush. It would do exactly what I had in mind with the curve direction reversal!
