Motion Blur ideas
Posted: Tue Apr 02, 2024 11:07 am
by Hoptoad
When Motion Blur is turned off during an animation, it doesn't make a keyframe. Sometimes I want Motion Blur on, and sometimes I don't; consequently, being able to turn it on and off throughout an animation would be nice.
Also, I think turning off Stroke for the extra images would be a nifty option (not the primary image). In some artwork, the Strokes on the extra images don't look right with Motion Blur. The duplicated Strokes make the art look too computer-y, and they can also foil the motion effect.
Also also, it would be nice to establish one's Motion Blur preferences in the Settings. And then a person could simply click a "Use preferences" button on the Motion Blur tab and import them.
Thanks. Keep up the awesome work.
Re: Motion Blur ideas
Posted: Tue Apr 02, 2024 3:23 pm
You might try putting a reference of the object behind the original. That way the reference layer visibility could be turned on and off, and you could remove the strokes.
Posted: Wed Apr 03, 2024 4:36 am
by Hoptoad
synthsin75 wrote: ↑Tue Apr 02, 2024 3:23 pm You might try putting a reference of the object behind the original. That way the reference layer visibility could be turned on and off, and you could remove the strokes.
That's a neat idea.
Unfortunately, I'm one of those people who consider reference layers an advanced feature that I generally avoid unless I have no choice.
Based on personal experience, using reference layers is like asking for things to go wrong while animating -- like whenever I try animating layers.
Posted: Wed Apr 03, 2024 4:00 pm
If you want to add the motion blur after the animation is done, you could just use a duplicate that has all the existing animation.
If you edit the animation, you'd just have to copy the keyframes over to the duplicate yourself.
Posted: Wed Apr 03, 2024 4:09 pm
by SuperSGL
A few years ago I animated characters running and opening different doors along a wall. I wanted to animate the camera so it effected the whole animation. So I was able to key frame the motion blur, also the characters weren't needing the motion blur all the time. I believe I key framed it but don't remember how I did it exactly. I'll have to look at the file. You could always reference the outlined objects and just add a slight blur to those while animating the motion blur on the rest of the object.
Sorry didn't read all the comments about reference. :oops:
Posted: Wed Apr 03, 2024 4:19 pm
by SuperSGL
Make sure you check "animated effects" in the layers tab. I was able to motion blur a shape moving left to right with motion blur on and off going back the other way I hope this helps
