More shortcut control like in other programs for a minor update version?
Posted: Fri Feb 02, 2024 9:31 am
Right now there are many shortcuts I want to change that I just can't.
Firstly, menu keyboard shortcuts don't allow you to not have "alt, ctrl, or shift" which makes it more tedious for me. Plus, when changing keyboard shortcuts currently, some inputs aren't accepted which is frustrating! For instance, if I wanted to change the Layer Selector tool to "Ctrl Shift", I can't for some reason, while other keyboard shortcuts allow you to use the modifier keys. These shortcuts should be fully customizable for every single one, but currently, they aren't !!
Secondly, there isn't a way to change the Layer Select from being "Alt + Right Click" to anything else, making switching between multiple programs harder. (Yes, I know you can change the "Layer Selector" tool shortcut, but that way is not as good since it doesn't automatically switch to the previous tool you were using.) The layer selection is a very useful shortcut, but I would like to change the shortcut to my liking.
Also, there is no shortcut for quickly renaming layers, instead, the best way is to click once on the name and wait a couple of seconds which is worse, especially when you have many layers you want to rename. I also think there should be a shortcut option to quickly move between the next layer and the previous layer.
Lastly, I can't map any shortcuts to my drawing tablet's buttons, my pen's buttons, or even any of the mouse's buttons - like left or right click!!!! This is super frustrating since all other programs I use, I have set common shortcuts to those buttons to speed up workflow.
Please, can you guys remake the way keyboard shortcut customization is done in Moho in the next minor version for the sake of our workflows? I would say, if the wiki lists a shortcut that can be used, it should be fully customizable to our liking.
Thank you for reading and thanks in advance!
