SS - Select Keys (v1.2.2)
Posted: Sat Dec 09, 2023 4:41 am
Provides one-click (or key) selection of animation keyframes in the full length of the timeline.
Features
The eligible keyframe keys can now be filtered for selection by:
Bones, Points, Shapes: Preselect items on the canvas (with their keys presented as selectable in the timeline). — This is how V1.00 worked.
New in V1.2:
Key Color: You can also preselect keys in the timeline, then only other keys with the same color(s) will be eligible for selection by the tool.
Frame Range: Use the Play Start and/or Play Stop markers to define and restrict the area of the timeline that will be in scope for the keyframe selection.
Frame Interval: If a Frame Range is set, and the frame playhead position (current frame) lies within the play range, then the offset between the start of play and the frame position will be used as the Frame Interval. e.g. Play Start on frame 2, End Frame at 96, Frame position at frame 4. Then keyframes between frames 2 and 96 (inclusive) on every 2nd/even frame would be eligible.
All can be used in any combination.
Summary
Works with:
- all selectable / non-selectable animatable item object properties i.e. for selected Bones, Points, Shapes.
- multiple selected layer timelines (visible in timeline)
- split transformation dimensions
- multiple object and property key types simultaneously (i.e. Bone transforms and Shape style/effects)
- matching keyframe colors- frame ranges and frame intervals
Version:
Features
New in V1.2:
Summary
Works with:
Version:
- version: 01.2.2#5512 MH12+
- release: 1.2.2
- by Sam Cogheil (SimplSam)
- latest release: ss_select_keys
- To install:
- Use the Moho ‘Scripts’ > ‘Install Script …’ menu (after you Download for Install Script, and extract the zip files)
- Save the ‘ss_select_keys.lua’ and ‘ss_select_keys.png’ files to your computer into your <custom>/scripts/tool folder
- Reload Moho scripts (or Restart Moho)
- Stan (and the team): MOHO Scripting – https://mohoscripting.com
- The friendly faces @ Lost Marble Moho forum – https://www.lostmarble.com/forum/
