Moho 14 Vector Issue
onurdemirsoy
Post by onurdemirsoy »
I opened my old file. At first it looks good but when I disable GPU Caching, this happened.
With GPU caching https://ibb.co/Wt0DZGm
Without GPU caching https://ibb.co/xD2WKGR
The problem is not only on the faces but there is an issue also on neck strokes.
So I think this is an issue and it happened in 14 but it is still good in 13.5
Is there a chance to solve it or should I wait for an update?
Thanks
Re: Moho 14 Vector Issue
What is your OS?
Are those lines related to a mask with exclude strokes enabled? it looks similar to this: https://www.lostmarble.com/forum/viewtopic.php?t=36365
Why do you want to disable GPU caching? Are you having any problem with it? Here I can't tell the difference with it on and off.
onurdemirsoy
I want to disable GPU caching because it makes the vectors blurry and also some other issues but if this is not solvable I will try to work like this. Thank you so much.
