visible layers
mikel
visible layers
Post by mikel »
hi,
I dont understand, why are not all layers visible at the same time?
Layers are only visible when i select them???
I dont get it. :(
Re: visibility
It sounds like you are selecting layers that are inside of a Switch layers.
Switch layers are a special type of group that only shows one of its layers at the time.
If this is the case and you don't want a switch layer there, you can select all the layers in the switch layer and move them outside.
mikel
Re: visible layers
Post by mikel »
No, its not a switch layer.
It was always different... it worked.
And now.. :/
If i select the group layer there is only the red square without any points i have made in any layer...
if i select one of them.. so i select the head. only the head layer is visible.
and so on..
i dont know.
mikel
Re: visible layers
Post by mikel »
https://photos.google.com/album/AF1QipP ... oMgvBhMXxc
here are some screenshots..
i need a break.
mikel
Re: visible layers
Post by mikel »
Re: visible layers
Doesn't look like you have any fill/stroke created.
But if you want to see the vector curves, you'll need to enable paths for each layer, in the quick settings.
And probably enable "paths for new layers" in the preferences.
Re: visible layers
Maybe you have Show Curves disabled?
When it's enabled, you'll see a check mark in the box and the curves should be visible for every layer.
This also depends on which tool you have selected. For example, if you have the Select Shape tool selected, it will show only shapes, not curves.
mikel
Re: visible layers
Post by mikel »
yes!
i dont know how i could uncheck both points unintentionally.
this also helped me with my invisible bone problem.
thanks.
