Creating a blank duplicate
justoshow
Post by justoshow »
Do anyone know of a script or way to duplicate a parent folder and goes through and clear all of the vector points?
I like to make blank folder structures for templating characters.
Normally I'll just manually go through each layer and delete the points my self.
SimplSam
Re: Creating a blank duplicate
Post by SimplSam »
Moho already includes a script to Erase All Vectors - which works on either a single vector layer or a group with vector children. Scripts > Draw > Erase All Vectors In Group
I have included a version below which allows you to erase multiple selected layers and/or all vector children/grandchildren/greatgrandchildren/... of a selected group - so you can select just the topmost group/s if all desired elements are contained in sub structures inside.
You can save the script 'lm_eraseall+.lua' to your Custom Scripts folder in the scripts\menu\Draw\ subfolder ... and it will appear as Scripts > Draw > Erase All Vectors In Group+ - after you restart Moho. Note: if you want to replace/remove the existing script command 'Erase All Vectors In Group' - then rename the file to: lm_eraseall.lua
https://drive.google.com/file/d/1A7SJ4E ... sp=sharing
justoshow
Post by justoshow »
SimplSam wrote: Sat Dec 31, 2022 12:06 pm Moho already includes a script to Erase All Vectors - which works on either a single vector layer or a group with vector children. Scripts > Draw > Erase All Vectors In Group
Wow. Thanks! I don't know how I missed that when I was looking through the scripts menu. I was half way through writing the script my self :lol: . I'll give that custom script a try to see if it does what I need it to do as the default script only clears the child vector layers and not the sub folders.
justoshow
Post by justoshow »
The custom script is exactly what I was looking for. Thank you very much!
Awesome SimplSam! I didn't even know about the original script before I read your post.
Thanks for the info and for also creating/posting your mod! Will check it out this afternoon.
