Movements in wrap layer fails to 'translate' movements into image layer
Posted: Tue Dec 20, 2022 3:03 am
by Hugging_Bear
Hi guys,
As you can see in this video, wrap and image layer got somehow disconnected. Does anyone knows how this happened (and to avoid this happening in the future)?
https://youtu.be/hY-2AFXIn3Q
Re: Movements in wrap layer fails to 'translate' movements into image layer
Posted: Wed Dec 28, 2022 11:20 pm
by Marik59
I recently made a production and I also had this same problem. I have dropped the project for the moment until I find a solution.
Posted: Thu Dec 29, 2022 8:33 am
by alanthebox
Hugging_Bear wrote: ↑Tue Dec 20, 2022 3:03 am Hi guys,
i admit i don't work with smart warps a lot, so, my tests might not match your workflow exactly, but i was able to recreate your issue on my first try. not sure how it got unlinked, but in my case, all i needed to do was go back into the layer settings for the image (in your case, "head - adult siegfried.png"), go to the image tab, and update the smart warp layer (in your case, "head - adult siegfried.png (warp)"). after that, everything worked as expected.
so, i guess my question is, have you opened up the layer settings and checked to see if the smart warp layer is still applied?
Posted: Fri Dec 30, 2022 1:44 am
by Hugging_Bear
alanthebox wrote: ↑Thu Dec 29, 2022 8:33 am
Thanks alanthebox for your tip. Next time, I'll know where to check and how to solve the problem. I assume it got disconnected because I moved the position of the smart bone dials in zero frame. With 'position' I mean the position of the base not the bone angle position.
