Bind the same layer to two different bones
Posted: Tue Nov 15, 2022 9:44 am
by ok_pepo
Hi! How are you? :-)
I'm a bit new on Moho and I don't know a lot of thing yet... So after read and read through all the Internet, I'm having the following question.
My work needs Sqash and Stretch on a Group layer, so, I decided to make it with a bone. The problem is that it needs two kinds of Squash and Stretch, one starting from the bottom, and one starting from the top. So, I thought on add two bones to the same layer, but then I realized that I only can Bind one bone per layer.
I'm thinking in duplicate the folder (Group Layer), make one Squash and Stretch for each folder and then change between them with a Switch Layer, but I don't know if it is a bad idea or a wrong way... Because I will finish my work with a lot of layers inside folders with more layers... And maybe it will end up being a little messy.
Also I thought adding another folder inside the group layer to generate another Bone Layer and make a different Squash and Stretch... But following this way I can't have all my bones in the same folder and I have to go to the specific layer for control it. I think I could do it with the second method, but maybe is a little disorganized...
Do you know another way or a simple way for do something like that?
Thank you!!! ^^
Re: Bind the same layer to two different bones
Posted: Tue Nov 15, 2022 10:19 am
by MrMiracle77
Victor had a thread the other day that might be applicable to your dilemma:
https://www.lostmarble.com/forum/viewtopic.php?t=35405
This uses two bones and allows the layer to tilt on two different axis. One tilt bone is parented to another. So Bone A produces effect A. Bone B produces effect B, but because Bone A is the child of B, it doesn't move when B moves.
I should ask how you're performing your squash/stretch? My favorite method is to hold shift and re-size the layer from an edge (not a corner). Holding shift causes Moho to retain the 'mass' of the layer. The center point of the squash/stretch is based on the designated center of the layer (little red +). So if you're using that method, you may want two bone layers, each with a different center point and smartbones.
Bone Layer 1 - (with high center and upper squash smart bone)
|- Bone Layer 2 - (with low center and lower squash smart bone
Since Layer 2 is only one layer below Layer 1, you can create a smart bone in layer 1 that controls the smartbone in layer 2, and have all your controls on the same layer.
Posted: Tue Nov 15, 2022 10:29 am
Stuff like this I do with the help of nested group/bone layers. Squash'n'stretch can be done without bones, I just have to place the origin correctly. So it's one origin on one layer and a different one on the other, this way they can be used separately.
Posted: Tue Nov 15, 2022 3:16 pm
by SimplSam
It may depend on what's in the Group. You could use:
- Overlapping opposing Flexi-bound 'stretch' bones (single bone layer) - simply relying on Bone strengths to do the work
- Layer-bound Bone Group inside a Layer-bound Bone Group - each with its own 'stretch' bone
- Or using smartbones to manipulate a Group within a Group layer (with Origins set) - simulating Squash & Stretch
- Or using smartbones to manipulate a Mesh - simulating Squash & Stretch
Posted: Thu Nov 17, 2022 2:21 am
by ok_pepo
Thank you all for your answers!!
MrMiracle77 wrote: ↑Tue Nov 15, 2022 10:19 am Victor had a thread the other day that might be applicable to your dilemma:
Yes, what I was thinking so far is to create two bone layers with two different bones, one starting on the top, and one starting on the bottom. With these bones I change the scale with the "Squash and Stretch scaling" checked on the Bone Constraints options and ready, I have Squash and Stretch :-D. The only problem was that I was not able to control all the bones from the same layer, and that was disturbing me ^^U. But with this method I thin I could do it very well!! Thank you!
slowtiger wrote: ↑Tue Nov 15, 2022 10:29 am Stuff like this I do with the help of nested group/bone layers. Squash'n'stretch can be done without bones, I just have to place the origin correctly. So it's one origin on one layer and a different one on the other, this way they can be used separately.
I also thought to do this, but I supposed that with Bones and the option on Bone Constraints checked could be more easy.
SimplSam wrote: ↑Tue Nov 15, 2022 3:16 pm It may depend on what's in the Group. You could use:
The Group Layer is containing a face with eyes, mouth and some letters. It's a logo. So, I think the best way is the second option, because the bones have to move everithing inside the folder at the same time, right?
Well. I think I have now a lot of possibilities and new ways to think and do when similar situations will arise.
Thank you very much to all!! :D :D
