Can "Minimize frame-to-frame randomness" be set globally?
Posted: Sat Jul 30, 2022 2:34 am
(I've noticed that many if not most of my questions deal with correcting mistakes I've made. Since I've seen this pattern with users of any software anywhere, I think I should judge the quality of any software by its ability to correct mistakes. It's easy to code something which follows a plan and the same sequence of actions every time. It's much harder to make all possible actions/options independent of each other.)
Title says it all:
Is there a way to set "Minimize frame-to-frame randomness" in the brush options
- globally in prefs
- globally for a whole document
- change it later after animation's already done?
There is an option with that name in project settings, but it only works for the stuff in the render style compartment, not for any brush used in shapes.
(I'd call this a mistake which should be corrected.)
Title says it all:
- globally in prefs
