MR Curve Tool 4.1
Posted: Sun Jun 19, 2022 7:46 am
This tool allows you to create points in Moho by just clicking the left mouse button instead of dragging and holding.
Version 2.0 new features:
1. Bezier Handles support
2. Auto-Weld option
3. Auto-Fill and Auto-Stroke options
Version 2.1 new features:
1. Use Bezier Handles option
2. Threshold option to activate Bezier handles
Version 2.2 new features:
1. Bug fixes
2. Added the ability to select points by holding Shift + Alt
3. Added the ability to delete selected points with the Delete key
Version 2.3 new features:
1. Bug fixes
Version 3.0 new features:
1. Added support for non-zero frame tool operation
2. Added Sharp corners option
3. Added the ability to use Shift for moving a point horizontally or vertically only
4. Added the ability to use Esc to end the curve at the last point created
5. Added grid snapping support for points
6. Added option to disable Bezier handles activation while drawing
7. Added ability to set cursor distance for activating Bezier handles
8. Added ability to select point by clicking on it
9. Added ability to delete selected points using Del key
10. Added the ability to move a selected point
11. Added the ability to weld a point by moving it onto another point or curve
12. Enter key now welds point to another point or curve in drawing mode
13. Now you can move the just-created point on the segment
14. Added ability to use Ctrl key to adjust curvature while moving a point
15. Added ability to use Alt key for unlocking neighboring Bezier handles when moving a point
16. You can control Bezier handles when one point is selected
17. Added an option to show Bezier handles for all points or just the selected one
18. Now, to continue an existing curve, double-click the existing point
19. Added the ability to select multiple points using Shift + Alt keys
- Add to selection using Ctrl + Shift + Alt keys
- Remove from selection using Ctrl + Alt keys
20. Added the ability to transform multiple points at once
- Added Skew transformation mode
- Added Distort transformation mode
- Added the ability to reset the pivot position with a double-click
- Added ability to deselect points by double-clicking away from pivot
21. Added options to enable/disable Transform Box controllers for Skew and Distort
22. Bug fixes
Version 4.0 new features:
1. Moho 14 support.
2. New Single Curve Mode in which you can modify the curvature and how many points the curve should be split into.
3. Added options to turn off the drawing mode.
4. Full support of the FBF layers.
5. No more “jumping” points or Bezier handles! This tool’s transformation works with points that are affected by smartbones and bones that are flipped.
6. Bug fixes and code optimization.
Download link: https://mohoscripts.com/script/mr_curve_tool
2. Auto-Weld option
1. Bug fixes
1. Bug fixes
22. Bug fixes
1. Moho 14 support.
