Page 1 of 2
Alpha not working on Mac?
Posted: Thu May 26, 2022 4:35 am
by Nicohk92
MOV files exported with Alpha (wther prores or png), don't have their alpha recognized by FCP or Motion5.
Have no choice but to export PNG sequence, which adds an extra time consuming step.
What am I missing?
Thanks
Re: Alpha not working on Mac?
Posted: Thu May 26, 2022 4:50 am
You need to choose the right codec: ProRes 4444, the 4 digits indicating it's 4 channels, rgb + alpha.
On older Macs it's the PNG codec, you need to check "millions+ colours" tehre.
Posted: Thu May 26, 2022 5:24 am
by Nicohk92
Odd, I don't have those settings.
https://www.dropbox.com/s/mmeymy23988cv ... 0.jpg?dl=0
Or maybe i m looking at the wrong place?
Posted: Thu May 26, 2022 5:44 am
Did you try those ProRes alpha settings in the 2nd group? You seem to run a different OSX version than I do.
Oh, and check there's not a layer covering the full frame at the bottom of all.
Posted: Thu May 26, 2022 5:51 am
by Nicohk92
I tried both yes.
It exports fine as PNG so there is nothing in the project itself.
I'm on Big Sur on those new M1 macs.
I remember 4444 being available on previous versions indeed.
Posted: Fri May 27, 2022 10:43 am
by Nicohk92
Anyone has the same problem?
Posted: Fri May 27, 2022 11:53 am
I don't normally render movie files out of Moho but I have seen this behavior with ProRes files rendered from the Windows version of Moho. The alpha channel is apparently there but for some reason it's not being read properly by some programs.
Other Windows users confirmed this issue and it seemed like this was a Windows specific problem because Mac users reported not seeing it. I think you're the first Mac user I've see to report it. I'll let the devs know this issue may be broader than previously thought.
In the meantime, I would render an image sequence from Moho (which is a recommended workflow for any animation program anyway,) and compile the frames to a movie file using another program.
Posted: Fri May 27, 2022 11:54 am
BTW, which release of Moho are you using? The comments I made above refer to recent versions of 13.5.x, not earlier versions.
Posted: Fri May 27, 2022 12:45 pm
by Nicohk92
Thanks!
Indeed I read about that Windows issue as well.
I'm on 13.5.4
And what of my export settings that are different than normal?
I should have many more choices right? (listed in the manual). Or am I looking at the wrong place?
Posted: Sat May 28, 2022 10:34 am
Which page in the manual are you referring too? (It will be easier for me if you post this info.)
Posted: Mon May 30, 2022 3:07 am
by Nicohk92
The output Format and Presets section on page 411.
It looks nothing like what I have:
Posted: Mon May 30, 2022 4:43 am
Could you please tell us Mac model and OS version you use?
Posted: Mon May 30, 2022 4:56 am
by Nicohk92
MacBook Pro (16-inch, 2021)
Apple M1 Max
OS Monterey 12.3.1
Posted: Mon May 30, 2022 10:18 am
by FloridaJo
Nicohk92 wrote: Mon May 30, 2022 4:56 am MacBook Pro (16-inch, 2021)
Apple M1 Max
OS Monterey 12.3.1
I also have an M1.
This is what I have for export:
Posted: Mon May 30, 2022 10:45 am
OK, this looks like the devs should look into it.
