Moho refresh bug
Posted: Sat Nov 13, 2021 6:09 pm
by davoodice2
hi.
until fix this bug you can use this script button.
https://www.mediafire.com/file/sd0g2yad ... h.lua/file
toggle enable disable with each time click
Re: Moho refresh bug
Posted: Sat Nov 13, 2021 8:15 pm
Doing moho.document:Refresh() every time you switch layers, enter/exit frame zero, etc. might cause a performance lag.
Posted: Sat Nov 13, 2021 11:17 pm
by davoodice2
synthsin75 wrote: Sat Nov 13, 2021 8:15 pm Doing moho.document:Refresh() every time you switch layers, enter/exit frame zero, etc. might cause a performance lag.
How can i find time line change? Even i just simple set key on key was exist before?
Posted: Sun Nov 14, 2021 12:40 am
I would at least check that the current layer has been shifted on the sequencer and it's a frame higher than the layer's start frame, so you only run the risk of slowing performance for layers/frames you really need it on.
Posted: Sun Nov 14, 2021 11:50 pm
by davoodice2
synthsin75 wrote: Sun Nov 14, 2021 12:40 am I would at least check that the current layer has been shifted on the sequencer and it's a frame higher than the layer's start frame, so you only run the risk of slowing performance for layers/frames you really need it on.
Yes you right.
For now i add tggle mode with diffrent sound.
