Export issue
Posted: Thu Oct 28, 2021 5:29 am
by carfer
Hi all,
I'm currently having an issue with exporting a Moho project file as video or PNG sequence. A pair of vitruvian bones has been used to alternate between two wings, represented as triangles in the attached example. Switching works fine in the development environment, but when I export the file as a movie or as a PNG sequence it no longer works, both triangles showing all the time. Of course, I could simply use a switch layer but I'd like to try the concept for further use.
Have I done something wrong or is it a Moho issue?
Thanks a lot.
https://www.dropbox.com/s/xmyfy1ob8sjgd ... moho?raw=1
https://www.dropbox.com/s/m1jyhotyv79py ... .mp4?raw=1
Moho 13.5.1 Build 20210623
system:
Windows 10 Home version 21H1 compilation 19043.1320
Processor: Intel(R) Core(TM) i7-10700F CPU @ 2.90GHz, 8 cores, 16 logical processors
32Gb RAM
Graphic card NVIDIA GeForce RTX 2080 Super
Graphic controller version 30.0.14.71.68
dedicated graphics memory 8192MB GDDR6
Re: Export issue
Posted: Thu Oct 28, 2021 9:10 am
The file has the v-bone disabled.
Re: Export issue
Posted: Thu Oct 28, 2021 9:23 am
by carfer
Oh dear, a most obvious mistake.
Thanks a lot, synthesin.
P.S. Anyway, why does <disable> affect only export?
Re: Export issue
Posted: Thu Oct 28, 2021 9:57 am
carfer wrote: ↑Thu Oct 28, 2021 9:23 am P.S. Anyway, why does <disable> affect only export?
It also disables in the workspace here, on Win 10 (not 21H1). Since I haven't ever seen disabled v-bones work in the workspace, I have no idea what could cause that.
Re: Export issue
Posted: Thu Oct 28, 2021 10:14 am
by carfer
OK, thank you very much again.
