URGENT - Workaround for a mask within a mask??
Posted: Sat Apr 01, 2006 11:47 am
by satanictesticles
Hi,
My current scene involves a character looking into a mirror.
The way the two objects (character and mirror) are structured is as follows
Within the character bones setup is an eyelid group to control the eyelids using masking.
CHARACTER (bones)
* eyelids (group) (with Masking settings of HIDE ALL + MASK THIS LAYER)
** eyelids (mask this layer)
** pupils (+add to mask)
** eyes (+add to mask)
Within the "Mirror" group is a duplicate but horizontally reversed clone of the CHARACTER bones animation, also using masking on the group to reveal the character in the glass but not the wood of the mirror.
MIRROR (group) (masking settings HIDE ALL + MASK THIS LAYER)
*character (BONES duplicate) (mask this layer)
*glass (+add to mask)
*mirror wood (do not mask this layer)
MY PROBLEM: When my character moves outside the glass area of the mirror, everything disappears as expected - except the pupils and the eyes, as these are masked under the character bones setup. So I have floating eyewhites + pupils where they are not wanted.
Can anybody suggest a way around this?
Thanks
Posted: Sat Apr 01, 2006 1:19 pm
I'd do the reflected character as a separate scene, render it as a video with a lossless codec, and import it into the scene into the mask of the mirror.
One can animate the whole scene with everything until the movements are OK, the copy the scene and erase everything which is not needed in that part, then render it.
Posted: Sat Apr 01, 2006 10:50 pm
This is a bit annoying but...
have you tried rendering?
Apparently nested masks do work... you can't see them in the edit view. They only show up in the render.
Try the set up you have and render one frame to check it. I just did an exact duplicate test and got the eye ball to mask even though in my edit/preview the eyeball appeared not to be masked.
the blue thing is the mirror... and there is a big face. You can see in this picture the eye is masked. In preview it doesn't show that way.
-Vern
Posted: Sun Apr 02, 2006 8:29 am
by satanictesticles
HA!! :roll:
You're right, heyvern, it doesn't even render. Maybe I should've tried that first instead of wasting your time, and my time! :D
Thanks for pointing out that stupidly simple answer for me!! Hehe.
:oops:
