Page 1 of 2
DV SELECT PARENT BONE LAYER V 1.8
Posted: Wed Sep 01, 2021 12:36 am
by davoodice2
quickly select neatest parent bone. best usage is if you assign a shortcut for it.
go back to bone layer and continue animate quickly.
download https://www.mediafire.com/file/x4iza6i7 ... 8.zip/file
1.7
- change algorithm
- auto collapse
- Auto focus
1.8
- bug fix
Re: DV SELECT PARENT BONE LAYER V 1.0
Posted: Wed Sep 01, 2021 2:36 pm
by funksmaname
Brilliant, thank you! will give it a whirl :)
edit:
Works great on direct level - can it look deeper? :idea:
Posted: Thu Sep 02, 2021 2:55 am
by davoodice2
funksmaname wrote: ↑Wed Sep 01, 2021 2:36 pm Brilliant, thank you! will give it a whirl :)
edit:
if you run tool again it goes one level up.
Explain more clearly if I do not understand what you mean
Posted: Thu Sep 02, 2021 1:22 pm
by funksmaname
I wondered if it was possible to keep going up a chain until you hit a bone layer, regardless of how deep you already are (a sub folders child layer doesn't go up to the bone) :)
Posted: Fri Sep 03, 2021 12:13 am
by davoodice2
funksmaname wrote: ↑Thu Sep 02, 2021 1:22 pm I wondered if it was possible to keep going up a chain until you hit a bone layer, regardless of how deep you already are (a sub folders child layer doesn't go up to the bone) :)
My main goal in this script was to go back to the main layer with one click when we go to the layers inside the rig and continue the animation or rig without worrying that the wrong layer will be selected.
but we can add a option for search more to find Rig layers outside of top layer.
Posted: Thu Sep 09, 2021 10:04 am
by davoodice2
davoodice2 wrote: ↑Wed Sep 01, 2021 12:36 am quickly select neatest parent bone. best usage is if you assign a shortcut for it.
download https://www.mediafire.com/file/9eisuqtp ... r.zip/file
Posted: Thu Sep 09, 2021 10:07 am
by davoodice2
Update 1.4
Posted: Thu Oct 28, 2021 3:24 am
by davoodice2
I think it work as you told ,now.
Re: DV SELECT PARENT BONE LAYER V 1.8
Posted: Mon Nov 15, 2021 2:46 pm
by Daxel
Thank you! I started using it, I love to go back to the bone layer so easily and being able to press it again to go another level up is great but it automatically collapses the children of the bone layer. I'm not sure if that is intended, I usually prefer to have the layers visible for the same reason that I like this script, to be able to move quicker between layers.
Posted: Thu Dec 16, 2021 10:15 am
by EricTheFish
Daxel wrote: ↑Mon Nov 15, 2021 2:46 pm but it automatically collapses the children of the bone layer.
Agreed, I prefer to keep the layer stack open too. I commented out the "Expand" code on lines 46,51 and 86. It works like a dream for me! :)
Great little tool, thanks for sharing davoodice2.
Posted: Thu Dec 16, 2021 12:11 pm
by ITAK
Thank you, davoodice2! Very, very useful tool!
Posted: Thu Dec 16, 2021 12:58 pm
by davoodice2
EricTheFish wrote: ↑Thu Dec 16, 2021 10:15 am
simple and easy! Enjoy
Posted: Thu Dec 16, 2021 12:59 pm
by davoodice2
ITAK wrote: ↑Thu Dec 16, 2021 12:11 pm Thank you, davoodice2! Very, very useful tool!
your welcome. i'm glad to hear this
Posted: Thu Dec 16, 2021 1:01 pm
by davoodice2
Daxel wrote: ↑Mon Nov 15, 2021 2:46 pm Thank you! I started using it, I love to go back to the bone layer so easily and being able to press it again to go another level up is great but it automatically collapses the children of the bone layer. I'm not sure if that is intended, I usually prefer to have the layers visible for the same reason that I like this script, to be able to move quicker between layers.
simply comment lines contain expand command with insert -- in line start
Posted: Thu Dec 16, 2021 2:44 pm
by Daxel
davoodice2 wrote: ↑Thu Dec 16, 2021 1:01 pm
Thanks, it worked.
I'm a programmer now 8)
