moho 13.5 is very unstable
davoodice2
Post by davoodice2 »
hi. based on my previous experience on moho 12.5 I think moho 13.5 is very unstable and crash frequently. I dont talk about simple scenes.
cpu ryzen 7 3700x
gpu rtx 2060 super
ram 32 gigabytes
wundows 10
Re: moho 13.5 is very unstable
Try disabling AutoSave. I've kept this feature disabled off since the initial release of 13.5, and the program has been very stable for me.
Version 12.0 had a similar problem in the beginning and it took a few updates for this bug to get squashed for that version. I'm guessing the same or similar bug has creeped back in for Moho 13.5. Hopefully, it will get fixed soon.
In the meantime, try disabling AutoSave, and manually and incrementally saving your files often (which everyone should be doing anyway, in any program.)
In my experience there is usually a broken reference causing slowdowns and crashes. You can delete it and create it again. There is also a script that removes negative keyframes that can be problematic (my problem is always a broken ref though).
I haven't tested 13.5 too much yet but what I can say is that there seems to be something wrong with the autosave feature because it has given me this "Failed to parse JSON document" error two times when trying to retrieve a save after a crash.
davoodice2
Greenlaw wrote: Wed Jun 23, 2021 9:13 am Try disabling AutoSave. I've kept this feature disabled off since the initial release of 13.5, and the program has been very stable for me.
you right. I disabled autosave and program has been stable. thanks.
