Blob brush creating stray points?
Posted: Thu May 13, 2021 11:37 pm
by SuperSGL
I reported this to support but they can't recreate it. It's not something I use that much anyway but decided to sketch out something using the blob brush at a low setting around .04 brush radius as I started leaving sketch lines all of a sudden It would create another point (node) off the page. It's a simple fix just delete the point but I'm wondering if anyone is having this issue? I'm using a wacom tablet Intuos Pro M
(I did just update the driver to the tablet but same result)
Re: Blob brush creating stray points?
Posted: Fri May 14, 2021 2:06 am
Yeah, it does that sometimes, stray points outside of the render frame. As far as I can tell, this occurs randomly, at least in 12.5 and earlier.
I haven't tested for this in 13.5 yet, but I imagine it still occurs since these tools haven't changed. BTW, are you using Moho 13.5? Just wondering if this is the case.
FYI, I used to see this when using my old Cintiq Companion 2. I'll see if it happens with my Intuos Pro or current Cintiq. I think resolution has something to do with it...I used to get different Freehand/Blob Brush errors between different model Wacom devices, or maybe it was from different screen res settings.
Posted: Fri May 14, 2021 6:19 pm
by SuperSGL
Thought I may have gotten the error in 12.5 as well and still used the intuos pro. I still have 12.5, 13 (for some reason?), and 13.5 mostly using the ladder. One of my old painter programs forget which version but after sketching for awhile it would draw a big fat line down the middle of the document (which wasn't in the UNDO) I had to try and paint it out or erase it
