Some Vector Layers Are Not Readering *Only* When Bones are adjusted
Posted: Wed Apr 28, 2021 10:31 am
by Phazor
I looked online for help but I didn't see anyone who had the same problem I'm having, so to save time, the issue is not the typical low opacity or visibility unchecked issue.
The specific problem I'm having is that all of my layers are visible until I move any bone. It doesn't matter which bone I move, but when I move any bone, some of my layers turn invisible and they also do not render. They temporarily turn invisible until I release the bone I'm moving, then they reappear.
I did not have that issue with Moho Pro 13, but I have this problem with Moho Pro 13.5 (and also Moho Pro 12).
Opacity is at 100%, visibility is checked in the layers and also layer settings, and I have the stage area Display Quality set to "High".
Does anyone have a solution to this problem?...
Re: Some Vector Layers Are Not Readering *Only* When Bones are adjusted
Posted: Wed Apr 28, 2021 11:02 am
Try disabling GPU acceleration in the display quality settings.
Posted: Wed Apr 28, 2021 11:07 am
by Phazor
Fantastic! It Work-eth!
I guess it makes your GPU run faster by removing some of the objects it's animating.
Posted: Wed Apr 28, 2021 11:15 am
Extra info: I normally keep GPU Acceleration disabled so I can view masked layers properly. (Or, more properly anyways.)
There are some situations where you may need to turn it back on, but usually off works for me.
Posted: Wed Apr 28, 2021 11:34 am
Phazor wrote: Wed Apr 28, 2021 11:07 am I guess it makes your GPU run faster by removing some of the objects it's animating.
I think the main thing GPU acceleration does is it rasterizes the vector art so the GPU can display it faster. Also, I think it makes Moho faster when your project mostly uses bitmap images.
But, as mentioned, GPU Acceleration can display masking incorrectly. I use masking a lot, so, for me, disabling this option is preferred, and I don't normally see much of a slow down when I disable it. (Of course, your mileage may vary depending on your CPU and GPU specs.)
Posted: Wed Apr 28, 2021 12:01 pm
by Phazor
Thank you guys!
