how to mask no selected bones ?
Posted: Sun Apr 11, 2021 2:51 am
by Fabionic38
Hi
When I select a bone in Moho, I would like to mask quickly all the other bones (no selected), but I don't find how to make that in the interface? There is only "Mask selected bones".. but I need the inverse ;). Someone could help me?
Re: how to mask no selected bones ?
Posted: Sun Apr 11, 2021 3:14 am
by SimplSam
If you mean to Hide un-selected bones, then I don't think that is available - but could be done in script.
One alternative is to select all bones, deselect the one/s you want to keep visible and then Hide Selected Bones.
Posted: Sun Apr 11, 2021 3:24 am
By 'mask', do you mean hide the bones? If so, you should use Hide Selected Bones or Shy Bones. To invert a selection, use Select Inverse or Ctrl-I.
So, to hide 'unselected' bones:
1. Select a bone
2. Press Ctrl-I
3. Select Hide Selected Bones or enable the Shy option.
When setting up character rigs, I like to use Shy instead of Hide because it's easy to toggle the visibility of 'shy-ed' bones if you set a hotkey for it. (I use the Shy button on my MQC panel for this.) I do this for bones that I don't want to touch during animation, but that I may occasionally need to reveal when editing the rig.
Posted: Sun Apr 11, 2021 4:12 am
by Fabionic38
Thanks Guys!
Yes, it's to hide bones ;)
I think I will use what you say : bones selection + Ctrl-I + shortcut to hide selected bones.
I'll try "shy bones" too, but that needs I activate "shy bones" before, and determinate at the beginning which bone is "shy" or not.
