Am I doing anything wrong? When I draw in FBF raster, I have a problem to check my drawings.
Indeed, it is impossible to check the motion from the cursor of the timeline. The strokes are rendered differently. What makes checking impossible, it's terribly problematic. I do not understand what's wrong. When I use the arrows keys, on the other hand, I can see my drawings correctly but that's not the way I want to use. Does anyone have this problem?
Help MOHO PRO 13 raster FBF is a disaster
Re: Help MOHO PRO 13 raster FBF is a disaster
Hey Neophite, could you post a screen recording?
@chucky How can i upload gif or pics from my computer ?
ok i uploaded from a website
Try enabling/disabling GPU acceleration.
YES ! Thanks a lot, enabled gpu acceleration works !
I have 2 more questions by the way,
1.How to avoid choosing a FBF folder each time?
I clicked save as default, but every time I create a layer FBF, (image type) I have to choose a folder.
2. I noticed that changing default shortcuts with custom shortcuts emits a sound every time. For example I modified my shortcut onion skin using alt + o, but a sound will be emitted each enabled state or disabled state. Do you know if there is a solution to that?
- alanthebox
Go to preferences, tools, and deselect "Enable audio feedback." Hopefully that does the trick!2. I noticed that changing default shortcuts with custom shortcuts emits a sound every time. For example I modified my shortcut onion skin using alt + o, but a sound will be emitted each enabled state or disabled state. Do you know if there is a solution to that?
