Vectors invisible at frame Zero
Posted: Fri Feb 22, 2019 8:07 pm
by Jkoseattle
I have a bunch of vector layers. I have to go to frame 1 to see them though. I went to frame 0, checked the Visible box, applied, but I still don't see them until frame 1. Why is this?
Re: Vectors invisible at frame Zero
Posted: Fri Feb 22, 2019 8:49 pm
Can you see the vector curves but without the shapes, or are the vectors missing too on frame zero?
Posted: Fri Feb 22, 2019 8:50 pm
by Jkoseattle
Yeah if I have a layer selected I can see the curves, but not the shapes.
Posted: Fri Feb 22, 2019 9:03 pm
I can think of a bunch of ways to make that happen but can't tell what's happening in your project without seeing it.
Can you strip down a copy of your project to one element that's invisible at 0 but visible elsewhere, and post it for examination?
Posted: Fri Feb 22, 2019 9:13 pm
Like Dennis says, it could be many things, like animated opacity on the style, a smart bone influence, etc..
Posted: Sat Feb 23, 2019 10:34 am
by hayasidist
my best guess -- do you have drawing tools enabled on all frames (i.e. not just frame 0)? if so did you draw the shapes on frame 1??
Posted: Sat Feb 23, 2019 9:12 pm
Oh, yeah, I totally forgot about that one! Sounds likely a likely culprit to me too.
This is one of the reasons I keep 'Drawing Tools Only On Frame 0' disabled until I absolutely need it, and then I disable it again promptly when I'm done. Drawing on a later frame is useful when you really need to, like when you want to draw something relative to a character's pose, but if you're not careful, leaving this option on can really mess up a project. It's safer to keep this option disabled most of the time.
Posted: Sat Feb 23, 2019 10:01 pm
I never use Drawing Tools Only On Frame 0. It's easy enough to copy any errant shape keys to frame zero.
Posted: Sat Feb 23, 2019 10:44 pm
True, but for me it's not worth the hassle when working in projects with hundreds of layers. Better to prevent the problem from happening at all.
