Sound Level
Posted: Mon Oct 22, 2018 7:17 am
by tosiyori
I have tried it all, and I can't set the "Sound Level" in Pro 12. I set the level in iTunes, imported into MOHO, the level is original. Using "Audio level" has no effect. The level shows 1, i set it to 001, no effect.
How can I set the Audio Level in Anime Studio MOHO Pro 12 ?
Re: Sound Level
Posted: Mon Oct 22, 2018 8:27 am
Just crank it up to 11. (Sorry, bad joke.)
Audio Level works here. Have you clicked Apply after changing the value and before closing the window?
BTW, just lifts up the whole volume which will probably sound noisy or cause distortions. IMO, you're better off editing and mixing audio in another program with better audio controls. A
typical workflow would be to render out your scenes for editing in a video editor like Vegas or Premiere, and use the tools there for your final audio mix.
Or, you can mix the audio the way you want it in an audio program and then import it to Moho. (I like to use Audition, Melodyne, and RX, but there are many out there, some of them free.)
In short, I wouldn't bother with editing and mixing audio inside Moho. You can sort of do it but it's really not designed for it.
