imported character does not fit in 3D scene & camera move
Posted: Mon Sep 03, 2018 6:54 am
by Marbelous
Hello,
I have the "moho start scene" with Bessie Coleman on the airport. Now I added William by Oguzhan Gunduz, and during the camera move that is in the Bessie-Coleman-Scene William is not standing in his place like Bessie, he is like sticking on the view port and flying in the air while the ground underneath him is moving.
I know this happening in AfterEffects when a 2D layer is put into a scene with 3D layers and camera, but I thought Moho does not have such a 3D-switch. Arent they "3D-layers" by default?
How can I make William also acting like a 3D-layer and standing really INSIDE the scene?
Re: imported character does not fit in 3D scene & camera mov
Posted: Mon Sep 03, 2018 7:54 am
by Víctor Paredes
Marbelous wrote:Hello,
Every layer in Moho has a Z position. You don't need to activate the way you do in After Effects. Just modify the Z value using the Transform layer tool (or hold Alt while dragging the mouse).
Also, you can navigate the 3D workspace using the Orbit tool.
Oh, and if I remember well, I think Bessie also has an option activated to always face the camera (you can check in the bone layer proprieties).
Posted: Mon Sep 03, 2018 8:47 am
William is set Immune to Camera in its main layer settings.
Posted: Mon Sep 03, 2018 9:18 am
by Víctor Paredes
synthsin75 wrote:William is set Immune to Camera in its main layer settings.
Haha! That's a better explanation. Thanks, Wes :)
Posted: Mon Sep 03, 2018 10:17 am
by Marbelous
I guess this was a joke, but he`s really not reacting to the camera.
I entered Bessies Z-value for him (in the text field, it didn`t work with alt and mouse (what exactly do I need to click? Im very sorry :oops: ).
I used the orb tool, Bessie is down on the ground on her airport, William is still right in front of the view port. And I can`t find any settings for this.
Posted: Mon Sep 03, 2018 10:35 am
No joke. Check the layer settings for his bone layer, general tab.
Posted: Tue Sep 04, 2018 10:10 am
by Marbelous
I wanted to reply "it is greyed out"...but I found this topic:
http://74.50.25.136/forum/viewtopic.php?f=13&t=23696
So when I put it on the top I could uncheck it.
Thank you for your help!
Posted: Tue Sep 04, 2018 10:50 am
Yes, top layer only. In general, you would drop everything you wish to be 'immune from camera' inside a Group layer. and then enable 'Immune To Camera' for the whole group. This is essentially the same as adding a 3D camera to a project in AE but disabling 3D for the layer. What's different is that Moho always has an active 3D camera.
Re: Moho's camera: I think Moho's camera is pretty good for most situations where the motion is fairly simple. You'll probably want to use the Orbit tool to see what it's actually doing in the project. Sometimes it helps to set the display into 2 or more views, with one view always set to the camera's POV and one in Orbit view.
When I need more complex camera choreography, I prefer to use Moho's Layer Comps to break out a project for After Effects, and use AE's camera instead. Animating the camera in AE can be easier because you can set up a hierarchy of nulls and targets for the camera, where Moho only allows you to animate the camera directly. Alternatively, I may use Fusion this way with Moho renders. When I need something even more complex, I might import the Moho rendered elements into an actual 3D program.
Posted: Tue Sep 18, 2018 12:22 pm
by Marbelous
Thank you very much for your help!
Combining AE with Moho sounds very interesting, i will definitely try that in the future...
