why my svg is not importing
patricia3d
Post by patricia3d »
i gave a svg file which not importing
This if jpg version of that svg because there is no option for svg
jezjones29
Re: why my svg is not importing
Post by jezjones29 »
How did you create the SVG?
You could trace your image in Moho > Draw > Trace image
It depends on what you want to do, but you'll probably find it best to draw it in Moho anyway.
patricia3d
one jpg image opened in gimp
edge deducted and opened in svg
and saved as svg plane
drawing using moho -> draw image is too tedus
if it could open in moho and i get vector lines, that will be better.
jezjones29
I thought Gimp was just a raster graphics editor. Maybe this is the problem? You should try inkscape.
But if you could make those lines a little clearer, you should be able to get a good result from the image trace in Moho.
