Exporting GIMP & Inkscape layers to import to Moho
Posted: Sun Feb 18, 2018 9:47 am
by 7cassandra
Hello. Does anyone know how to export layers from GIMP and Inkscape so they can be imported into Moho? Every way I've tried merges the layers into one layer, distorts the layers, etc. Thanks! :)
Re: Exporting GIMP & Inkscape layers to import to Moho
Posted: Sun Feb 18, 2018 11:23 pm
by chucky
There's a great script that process PSDs In Gimp into layered pngs wrapped up in a Moho file.
It's not easy to find or install but it is very good.
Inkscape is easier just export an SVG.
Posted: Mon Feb 19, 2018 12:56 am
by Sketch_Turner
Sometimes Moho imports Inkscape SVGs incorrectly. If you're experiencing distortions, switching to .eps format should help.
Posted: Mon Feb 19, 2018 1:44 pm
by Rainer
Just to add, I think there's also a plugin for Inkscape that imports layers to Moho/AS. I also think I recall (some time since I've had to do it) that if you import an .svg it imports layers as objects all on the one layer. You theoretically can use Scripts>Layer Effects>RT:Break Apart Shapes to convert the objects to layers, success depending on how you've organised your Illustrator/Inkscape file - probably a bit of a mess if you're importing 3d objects.
Posted: Mon Feb 19, 2018 8:19 pm
by patricia3d
I am not able to import in moho12
viewtopic.php?f=13&t=31822
