Disattach Points?
jasonbice15
Disattach Points?
Post by jasonbice15 »
Does anyone know how to disattach points that have been welded together by mistake?
Thanks
Re: Disattach Points?
That's not possible but you can add points to the paths joined by that welded point, and then delete the welded point using the Delete Edge tool in Point mode. Add these points somewhere near the welded point.
The added points should help hold the shape of the original paths from before the welding. After deleting the welded point, you can decide to keep or remove any of these added points as necessary.
jasonbice15
Thanks!
