Problems with bones
Posted: Mon May 08, 2017 2:59 pm
by Smiler Entertainment
Hey guys, I'm having a big problem.
So I finished the body of a character (finally, thank God) and have added bones and binded them to points and body parts, there's just one problem. When I grab, say... the left arm, it moves not only itself but the entire body. And I've been looking at bone strength, if the parts were binded correctly, etc.
How do I fix this without starting a whole new character? Because I need to finish a project by next Tuesday.
Re: Problems with bones
Posted: Mon May 08, 2017 4:49 pm
Sounds like it could be a parenting issue. Check the hierarchy.
Posted: Mon May 08, 2017 4:54 pm
Greenlaw wrote:Sounds like it could be a parenting issue. Check the hierarchy.
Check the what?
Posted: Mon May 08, 2017 4:59 pm
Check that the parenting of the limbs is correct. i.e., the hand bone connected to the lower arm bone, the lower arm bone connected to the upper arm bone, the upper arm bone connected to the upper torso, etc.
In other words, from your description, it sounds like the body's hip or root bone may be parented to one of the arm bones. Or something like that.
Posted: Mon May 08, 2017 5:06 pm
Greenlaw wrote:Check that the parenting of the limbs is correct. i.e., the hand bone connected to the lower arm bone, the lower arm bone connected to the upper arm bone, the upper arm bone connected to the upper torso, etc.
Everything's connected appropriately from what I can tell.
Posted: Mon May 08, 2017 5:35 pm
Hmm. Not sure then. Without more info, screencaps or a test scene, anything will just be a guess.
The most likely issue would be incorrect hierarchical structure as mentioned, but it may also be in an error in one of your Actions (probably in an arm bone) or an incorrect binding method. Or a combination of any of these.
Posted: Wed Jun 28, 2017 12:21 pm
Greenlaw wrote:Hmm. Not sure then. Without more info, screencaps or a test scene, anything will just be a guess.
If you want, I can attach the file and let you see what's wrong, since I can't figure that out.
Posted: Fri Jun 30, 2017 5:38 pm
by dueyftw
Please do. We can help you more with seeing what is wrong. All so let use know want version your using.
Dale
Posted: Fri Jun 30, 2017 6:51 pm
dueyftw wrote:Please do. We can help you more with seeing what is wrong. All so let use know want version your using.
Dale
Okay.
My version number is Moho 12, 2, 0, 21774. This is Debut 12 I'm using here.
I'm not sure how to attach a file here. Do you mind if I email you the file?
Posted: Fri Aug 11, 2017 12:09 pm
Dale
Hello?
Posted: Fri Aug 11, 2017 12:50 pm
by dueyftw
Sorry, On the road for two days.
Send me a message on this forum with a link.
Dale
Posted: Fri Aug 11, 2017 3:06 pm
dueyftw wrote:Sorry, On the road for two days.
Dale
Nevermind. My bones were parented incorrectly.
