Translate Shapes?
Posted: Sun Apr 30, 2017 2:35 am
by uncle808us
I created a bunch of shapes in one layer these can all be selected using the select shape tool. But is there a way to rotate move ore scale the shape once it is selected? Or is fill /stroke the only thing you can do to a selected shape? I looked in the manual but found nothing. I used the script.RT break apart shapes but I wanted to know if you can translate (scale,rotate,move,) shapes? Thanks Anime Studio Pro 11.
Re: Translate Shapes?
Posted: Sun Apr 30, 2017 2:40 pm
by VĂctor Paredes
Vectors in Moho and made by two elements: Points and Shapes.
The shape is only the color of the stroke and fill. If you use the select shape tool, you can modify that colors.
If you want to modify the form (scale, translate, rotate, etc), you need to select the points related to that shapes and use the Transform Points tool to move the points.
If you want to select all the points surrounding a specific shape, use the Select Points tool and click over the fill of the shape you want. The software will automatically select all the points related to that fill.
Remember you can add more points to the selection by holding Shift and clicking over other points/fills.
I hope this helps.
Posted: Sun Apr 30, 2017 3:07 pm
by uncle808us
Yes it did help I have one question about adding points do you click right on an existing point with the add point tool?
