Pin Bones
Posted: Tue Feb 28, 2017 6:30 am
by toshiyori
When using "Pin Bones" how do you get an image ? I watched the tutorial several times and it only stated: using vectors. now, if a image is applied to the vector, how does the "Pin Bones" work ?
Re: Pin Bones
Posted: Tue Feb 28, 2017 6:58 am
After importing your image, go to its Layer Settings and, under the Image tab, choose the deforming Mesh layer.
The thing to be aware of is that the bones do not deform the image. The bones deform the mesh, which then deforms the image. The bones, of course, are animated from the Bones layer.
Pin Bones are animated like regular bones, you can parent them, scale them, move them around and rotate them. The manipulators are a little different though--use Alt, Shift, and Ctrl to transform them. (Described in the tool tips.)
Edit: Just checked to confirm what I wrote. Apparently, you can scale the Size of a Pin bone only after frame 0, but you can scale its Strength at frame 0.
Re: Pin Bones
Posted: Wed Mar 01, 2017 6:30 am
by toshiyori
I can go all the way until I reach: "Image Tab" I can't locate "Deform mesh Layer"
I'll try to attach the image tab.
I tried, no luck !
Re: Pin Bones
Posted: Wed Mar 01, 2017 6:35 am
by dueyftw
Look at 4:46
Dale
Re: Pin Bones
Posted: Wed Mar 01, 2017 7:46 am
Are you using Pro or Debut? That might be a Debut limitation. I think Debut supports Pin Bones but does not support Smart meshes. Pin bones should still work in Debut with images, but I believe you can't create and apply a custom deform mesh in Debut. Note that I'm not completely sure about that so you'll have to check the specs for each version.
If you're using Pro, I think you're going to need to post screen caps or a sample scene to better illustrate the problem.
Re: Pin Bones
Posted: Fri Mar 03, 2017 9:20 am
by toshiyori
I'm using Moho 12 Pro, I have got through the problems I was having, Now I'm enjoying Pin Bones.
Thanks for your advice.
