Old import image sequence script
Breinmeester
Post by Breinmeester »
Does anybody still have the old script that allowed an image sequence to be imported as a switch layer? It would be greatly appreciated if someone could share it. Thanks!
amanandink
Re: Old import image sequence script
Post by amanandink »
Is it is optional script in your custom content folder
Moho Pro\Extra Files\Optional Scripts\menu\Image\js_image_sequence.lua
DK
Post by DK »
Just use the new import image sequence script. After it has imported the image sequence, right click on the icon and select convert to switch layer.
D.K
dueyftw
Post by dueyftw »
The old import image sequence script had a problem with numbering. The new one has suppose to fix the problem.
Dale
Breinmeester
Thanks guys!
DK wrote:Just use the new import image sequence script. After it has imported the image sequence, right click on the icon and select convert to switch layer.
D.K
Oh, geez, I totally forgot it can do that. :P
Thanks for the tip. I think it gave me some interesting workflow ideas to test out.
