Pls, help to improve my new 2.5D arm construction.
Posted: Mon Nov 21, 2016 1:19 pm
by Lychee
Hello.
I created an new kind of arm (leg) construction based on animation of joints and It work not bad, but it's not perfect.
The elbow joint work good but sometime i have problems with some offset on the wrist joint, certainly a bad influence from another bone.
I tried alot of contructions for this result an i have no idea of how to correct my problem.
Please help me before my brain is burning.
The only drawback I see is that the elbow isn't solidly connected.
EDIT: I updated the link to fix the floating elbow.
Re: Pls, help for improve my new 2.5D arm construction.
Posted: Mon Nov 21, 2016 5:54 pm
by Lychee
Thank's Synthsin.
It is a script? It sound good but i'm not at home to test it, so i will try later.
Posted: Mon Nov 21, 2016 6:12 pm
Just another way to rig it, using bone stretch instead of the smart bones for scaling. I updated the above link since I figured out how to keep the elbow connected, even when you drag the target far way.
I have the wrist target parented to the elbow target, so it doesn't get left behind, but you can unparent that if you don't like it.
Posted: Mon Nov 21, 2016 10:47 pm
by Lychee
Thanks again, this is exactly the way I wanted it to work, I tried something like that in the past, but without success.
But there is something I don't understand, how did you made so that the bone is stretched to their normal sizes to the zero image?
I have search in offset bone but I found nothing to help me understand.
Posted: Mon Nov 21, 2016 11:18 pm
Lychee wrote:But there is something I don't understand, how did you made so that the bone is stretched to their normal sizes to the zero image?
It's a trick Victor came up with. On frame one you scale the bone to .01, copy that key to frame zero, and then delete the frame one scale key. Now frame zero has a .01 scale baked in. Then you set the Maximum IK Stretching to 100 to compensate for the scaling. So 100x.01=1, which is the default scale of a bone, but now the bone can stretch from .01 to 1, instead of from 1 to whatever you set the Max IK Stretch to.
The extra bone at the elbow is needed to kill the IK, so that the child stretch bone has something to stop it from scaling down to .01. The target bone usually does this, but when you have a chain of two or more of these stretch bones, you need to kill the IK to the chain.
Since it looks like you used Smooth Joint Bone Pair, which won't work with my rig, you'll also probably need another elbow bone to handle the points at the elbow. If you have any trouble, I can rig it up to your arm for you.
Re: Pls, help to improve my new 2.5D arm construction.
I also added a little trick I like to use so limbs maintain their volume when pointed directly at the camera. Let me know what you think.
Posted: Tue Nov 22, 2016 8:05 am
by neeters_guy
Neat! This is a clever use of target bones. Thanks for sharing.
Posted: Tue Nov 22, 2016 10:23 pm
by Lychee
1000 times thank you, you've greatly improved my build and now it works perfectly.
I also had the idea of putting additional forms for kept the thickness to the members of my old creations, but it was at the time or I tried to create things using true 3D of Moho. https://www.youtube.com/watch?v=yN2rR1deFDc
For this test I had put a smartbone to hold the compression of shape and kept this thickness, but the addition of another form seems like a better idea.
I made changes to your changes , I put the little IK killer bone in the same direction of the thigh and reduced its angle constraint to zero, like that I was able to get back smooth joint for bone pair.
I prefer to use smooth joint for bone pair to control some points more easily and more naturally (too bad we can put only one by layer)
I also added shapes to mask unwanted parts of the cross-section view.
The Selgin trick is usefull and it must be a part of Moho, perhaps add scale control in the offset bone section.
Look at my link above that I have updated and tell me what you think.
Posted: Tue Nov 22, 2016 10:55 pm
Lychee wrote:1000 times thank you, you've greatly improved my build and now it works perfectly.
Glad I could help. Yeah, I noticed your smart bones for scaling limited it so the volume would be maintained.
Very nice changes. If I would have worked on it more, mine could have looked better, but I don't think I would have thought to sandwich the limb between the fill and stroke of the cross-section. Nice idea. Great idea to align the extra IK killing bone and use that for the Smooth Joint too.
Nice collaboration. This might just be the perfect limb rig now.
Posted: Wed Nov 23, 2016 1:13 am
by funksmaname
Good work you guys!
Posted: Sun Nov 27, 2016 3:31 pm
by Lychee
I did some small updates on the file to try to simplify my build, I think it's now something finished.
I am now trying to have a version with a twist of the elbow more toony.
