Moho Pro 12 Switch Selection Question?
Posted: Thu Aug 18, 2016 2:22 am
by EHEBrandon
Okay so I was wondering if there was a way to make the switch selection apart of the UI instead of a separate window or tab. It would make it so much more convenient if we can. Like if we could put it right under the coloring options or even in that empty section on the tools area. Also I notice the lips don't change until you stop it would be cool if they changed while you were moving the slider.
Re: Moho Pro 12 Switch Selection Question?
Posted: Fri Aug 19, 2016 8:17 pm
by emartin
EHEBrandon wrote:Okay so I was wondering if there was a way to make the switch selection apart of the UI instead of a separate window or tab. It would make it so much more convenient if we can. Like if we could put it right under the coloring options or even in that empty section on the tools area. Also I notice the lips don't change until you stop it would be cool if they changed while you were moving the slider.
Not currently. It is a good idea though.
Honestly we've considered what would have to happen to make more dialogs dockable, but it is not an easy task.
Posted: Fri Aug 19, 2016 10:11 pm
by -RR-
A great thing (if you can't do it already) would be the ability to assign two shortcut keys to through the switch layers, one forward and one back.
