How to select a bone and NOT add a keyframe
Hi all,
How to control this? Is there a keycombination to do this?
Now I get keys if I just want to check on some bone, or make adjustments to the bone. Maybe I missed something, but this shouldn't surely be the case?
- Víctor Paredes
Re: How to select a bone and NOT add a keyframe
Use the Select Bone tool.
I would really like that too. Having to switch to the Select tool is a pain in the bum. I'd rather work only in the manipulate tool if possible.
- Víctor Paredes
In the meanwhile, you can use B as a sticky key. That works in a similar way to a modifier key like Alt, Ctrl or Shift.Dodgy wrote:I would really like that too. Having to switch to the Select tool is a pain in the bum. I'd rather work only in the manipulate tool if possible.
So, you are working with the Manipulate bone tool and when you want to select a bone, hold B (the shortcut for Select Bone tool) in the keyboard and select the bone you want. Once you release B, Manipulate Bones tool will be the current again.
- funksmaname
I didn't know that! seems to work on all tools?! w00t.
(you must release mouse before key)
How long has this been implemented!? and why didn't anyone tell me about it?! *huff*
I think sticky keys was introduced in 11.
We all talked about it, Danny, and we were sure your knew about this.
- funksmaname
Awesome sauce! Thank you!Víctor Paredes wrote:In the meanwhile, you can use B as a sticky key. That works in a similar way to a modifier key like Alt, Ctrl or Shift.Dodgy wrote:I would really like that too. Having to switch to the Select tool is a pain in the bum. I'd rather work only in the manipulate tool if possible.
