Is there a short way to write a name to the bone
onurdemirsoy
Post by onurdemirsoy »
Everytime I draw a bone, I have to go and click this part Image
and write a name. It is really a pin when you have hundreds of bones. Is there an easier way or a shortcut to add names immediately after adding bones?
Re: Is there a short way to write a name to the bone
There's a preference to auto-name new bones, but you'd have to modify the add bone tool to throw up a dialog if you want to name each bone as you create it.
A better option may be to copy bones from an existing rig that already has named bones.
onurdemirsoy
synthsin75 wrote:There's a preference to auto-name new bones, but you'd have to modify the add bone tool to throw up a dialog if you want to name each bone as you create it.
Thanks. I already know these but thank you so much.
obtusity
Post by obtusity »
If you literally have hundreds of bones, with the new file format it is now much easier to modify the .anime file directly with moderately simple programming.
Useful links:
onurdemirsoy
obtusity wrote:If you literally have hundreds of bones, with the new file format it is now much easier to modify the .anime file directly with moderately simple programming.
Useful links:
Thank you so much. I am going to read these documents.
