brushes
Posted: Fri Dec 23, 2005 11:41 pm
by ulrik
I discovered a possible bug, I made a rectangel with auto fill and auto outline checked, then I selected the shape and changed the outline to a brush ( I had view "brushes" checked in "display quality" so I could see the result), everything looked fine, then I changed back to "no brush" in styles window but the brush is still there when wiewing in working area but it's not there when rendered.
Posted: Sat Dec 24, 2005 12:16 am
by Rasheed
I have noticed the same behaviour in v5.3.1.
The way I work around this is that while you select the None brush, you set both the Brush jitter angle and the Brush spacing to zero. Alternatively, you can save and reload the file.
Posted: Sat Dec 24, 2005 12:19 am
by ulrik
thanks Rasheed, I'll try that right away :)
