Old-school trick for 3D effect
Posted: Thu Dec 22, 2005 3:12 pm
by macton
Since this topic comes up quite a lot, I'd like to share a simple old school game technique for making psuedo-3D characters.
The basic idea
1. Separate your character into small component parts (e.g. head, iris, pupil, etc.)
2. Build each part in a separate vector layer
3. Move each layer's depth (Z translation) so that the center of the layer is where it would be if your character was actually 3D.
4. Use "Rotate to face camera" and "sort by depth" on each vector layer.
This effect is not for everything, there are a lot of little caveats and bones are right out (in general), but there is the definate advantage of only having to do the animation from one angle. And since there is no point animation, it should be fairly Flash friendly.
There is the additional problem of Moho's "rotate to face camera" option is calculated (Sorry LM...) completely wrong IMO. So if you are using Moho's renderer (We're not here, so it's not so much a problem for us.) you will see the most problems as either the layer or camera rotates about the x axis.
To give you the idea visually:
Character built with separate layers in their proper depths
http://crashcore.com/public/moho/exampl ... facing.swf
http://crashcore.com/public/moho/exampl ... acing.moho
Character with vector layers set to face camera
Here's hoping this helps someone!
NOTE: These files are provided for informational purposes only.
Posted: Thu Dec 22, 2005 4:30 pm
by bupaje
That dog looks pretty good -thanks for the tip.
Cool Trick
Posted: Tue Dec 27, 2005 7:28 pm
by saintmovius
That is an awesome trick!! Any way we could see the Moho file to get a better understanding?
Re: Cool Trick
Posted: Wed Dec 28, 2005 11:38 pm
by macton
saintmovius wrote:That is an awesome trick!! Any way we could see the Moho file to get a better understanding?
See above. Note that these files are copyrighted (They are provided for instructional purposed only.)
You'll see that the 3D view is completely based on the camera (i.e. The camera is just doing a simple orbit) and no modifications to the character are done based on view angle.
