PrepMultiUndo()
Posted: Wed Mar 23, 2016 3:16 pm
by lehtiniemi
How do I use PrepMultiUndo()? I'm performing things that affect multiple layers, does this help undo those in one go?
I have a situation where I don't know in forehand which layers will be touched. Instead of force-adding PrepUndo() to each layer even if they're not touched, I was wishing this could maybe be a solution?
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 3:26 pm
PrepMultiUndo is a document class function, so just call it before making the changes you want to be undoable.
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 3:32 pm
by lehtiniemi
synthsin75 wrote:PrepMultiUndo is a document class function, so just call it before making the changes you want to be undoable.
I tried to use it like that, but for some reason this happened:
-When using only PrepMultiUndo, only one undo-step is added and it doesn't undo all the changes to different layers, only like for one layer
-If I try to use PrepUndo(layer) multiple times withing the document, then for some reason a right amount of undo steps is added, but they aren't undoed properly
-If I use PrepMultiUndo and add PrepUndo(layer) on each layer, then the amount of PrepUndo-steps is added and they are undoed properly.
I don't know what's happening, if I'm doing something wrong or is PrepMultiUndo supposed to be called if you use PrepUndo many times?
Or can I somehow use PrepMultiUndo to add only one undostep that undoes all the changes on separate layers? From your message I understand it's supposed to work like this but for some reason it doesn't undo changes on all layers.
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 3:38 pm
Maybe you need to use it with the argument. PrepMultiUndo(true)
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 3:41 pm
by lehtiniemi
synthsin75 wrote:Maybe you need to use it with the argument. PrepMultiUndo(true)
Doesn't seem to work. :/ Tried with both true and false and all the combinations of PrepMultiUndo() and PrepUndo() mentioned in my original post.
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 3:47 pm
Then you may need to provide a working code snippet to test what you are actually looking to do.
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 4:23 pm
by lehtiniemi
synthsin75 wrote:Then you may need to provide a working code snippet to test what you are actually looking to do.
I can post my whole script, but this is how I'm trying to make it work:
PrepMultiUndo(true)
... code to move keyframes around in multiple layers
I would like this to produce only one undo step that undos all the keyframe changes. For some reason, this only undos changes for one layer.
If you want to have a look, here's the whole tool script. Currently I'm adding a PrepUndo(layer) for every layer I go through because I couldn't get the multiundo to work. Of course, this is pain when there are tens of layers. It doesn't even check if they are changed, currently. Work in progress. It's currently using my own function to find keyframes, I'll switch to your technique but haven't done it yet.
This script will make it really easy to insert and cut time in ASPRO, undo is now the only thing that's not working...
ScriptName = "JL_time_tool"
JL_time_tool = {}
function JL_time_tool:Name()
	return "Time tool"
end
function JL_time_tool:Version()
	return "1.0"
end
function JL_time_tool:Description()
	return "Insert or delete time by dragging in the viewport. Insert by dragging right, delete by dragging left."
end
function JL_time_tool:Creator()
	return "Juhana Lehtiniemi - www.juhanalehtiniemi.com"
end
function JL_time_tool:UILabel()
	return "Time tool"
end
-- Recurring values
JL_time_tool.startFrame=0
JL_time_tool.endFrame=0
JL_time_tool.originaLayerPos=nil
JL_time_tool.originaBonePos=nil
JL_time_tool.selectedBone=nil
JL_time_tool.selectedLayer=nil
JL_MSG_not_a_bone_layer = "Current layer is not a bone layer."
JL_MSG_select_one_bone_only = "Please select 1 bone only. You can select a bone by ALT-clicking it."
-- The guts of this script
function JL_time_tool:FindKey(moho, selectedVec, startFrame, direction)
	local keyframe = 0
	local frameCount = selectedVec:Duration()
	if (direction < 0) -- backwards
	then
		for i = startFrame, 0, -1 do
		-- Start from one frame before current frame
			if (selectedVec:HasKey(i)) then
				-- bone.fAnimPos:HasKey(curFrame - i)==true
				keyframe = i
				break
			end
		end
	else -- forward
		for i = startFrame, frameCount do
				keyframe = i
				break
			end
		end
	end
	return(keyframe)
end
function JL_time_tool:InsertTimeToChannel(moho, channel, startFrame, endFrame)
	-- Add AMOUNT to animation length or not?
	local nextKeyframe, nextKeyframeID
	local modified = false
	if channel:CountKeys() > 1 then
		-- Chronological start and end frames
		local newStartFrame, newEndFrame
		-- Calculate loop direction
		local direction, offset
		-- If user selection is from left to right, then we're starting from the end to insert time
		if (startFrame < endFrame) then
			direction = -1
			newStartFrame = startFrame
			newEndFrame = endFrame
			offset = endFrame-startFrame
	 		-- Search next keyframe backwards from the end of the channel
			local foundKeyframe = self:FindKey(moho, channel, channel:Duration(), direction)
			-- Repeat until given frame reached
			while (foundKeyframe >= newStartFrame) do
				nextKeyframeID = channel:GetClosestKeyID(foundKeyframe)
				channel:SetKeyWhen(nextKeyframeID, foundKeyframe+offset)
				-- Search backwards for next keyframe after the last found keyframe
				foundKeyframe = self:FindKey(moho, channel, foundKeyframe-1, direction)
				-- if (foundKeyframe == 0) then break end
				-- Changes to channels done
				modified = true
			end
		else
			-- If user selected the range backwards, then we have to start from left to right to delete time
			direction = 1
			newStartFrame = endFrame
			newEndFrame = startFrame
			local foundKeyframe = self:FindKey(moho, channel, newStartFrame, direction)
			while (foundKeyframe <= channel:Duration() and foundKeyframe ~= 0) do
				-- Search for next keyframe after the last found keyframe
				foundKeyframe = self:FindKey(moho, channel, foundKeyframe+1, direction)
				modified = true
			end
		end
	end
	return modified
end
function JL_time_tool:InsertTimeToLayer(moho, layer, startFrame, endFrame)
	local numCh = layer:CountChannels()
	-- Currently prepping undo for every channel because I can't check if they will be changed
	moho.document:PrepUndo(layer)
	for i = 0, numCh - 2 do
		local chInfo = MOHO.MohoLayerChannel:new_local()
		layer:GetChannelInfo(i, chInfo)
		if (chInfo.subChannelCount == 1) then
			local ch = layer:Channel(i, 0, moho.document)
			-- print(MOHO.Localize("/Scripts/Menu/ListChannels/Channel=Channel ") .. i .. ": " .. chInfo.name:Buffer() .. MOHO.Localize("/Scripts/Menu/ListChannels/Keyframes= Keyframes: ") .. ch:CountKeys())
			if (self:InsertTimeToChannel(moho, ch, startFrame, endFrame)) then
				modified = true
			end
		else
			-- print(MOHO.Localize("/Scripts/Menu/ListChannels/Channel=Channel ") .. i .. ": " .. chInfo.name:Buffer())
			for subID = 0, chInfo.subChannelCount - 1 do
				local ch = layer:Channel(i, subID, moho.document)
					modified = true
				end
				-- print(MOHO.Localize("/Scripts/Menu/ListChannels/SubChannel=    Sub-channel ") .. subID .. MOHO.Localize("/Scripts/Menu/ListChannels/Keyframes= Keyframes: ") .. ch:CountKeys())
			end
		end
	end
	-- if (modified) then
		-- moho.document:PrepUndo(layer)
	-- end
	return modified
end
function JL_time_tool:InsertTimeToGroupLayer(moho, groupLayer, startFrame, endFrame)
	for i = 0, groupLayer:CountLayers()-1 do
		local currentLayer = groupLayer:Layer(i)
		if (self:InsertTimeToLayer(moho, currentLayer, startFrame, endFrame)) then
			modified = true
		end
		if (currentLayer:IsGroupType()) then
			-- Go through the group layer as well
			if (self:InsertTimeToGroupLayer(moho, moho:LayerAsGroup(currentLayer), startFrame, endFrame)) then
				modified = true
			end
		end
	end
	return modified
end
function JL_time_tool:OnMouseDown(moho, mouseEvent)
	local curFrame = moho.layer:CurFrame()
	self.startFrame = curFrame
	if (self.startFrame == 0) then
		LM.GUI.Alert(LM.GUI.ALERT_INFO, "Start frame number has to be other than 0.", nil, nil, "OK", nil, nil)
		return false
	end
	return true
end
function JL_time_tool:OnMouseMoved(moho, mouseEvent)
	if (self.startFrame == 0) then return false end
	local mouseGenValue=mouseEvent.pt.x-mouseEvent.startPt.x
	if (mouseEvent.shiftKey) then
		self.endFrame = self.startFrame+math.floor(mouseGenValue/50)
	else
		self.endFrame = self.startFrame+math.floor(mouseGenValue/25)
	end
	if (self.endFrame < 0) then
		self.endFrame = 0
	end
	local range = self.endFrame-self.startFrame
	if (range > 0) then
		self.selectionRangeText:SetValue(self.InsertText.." "..math.abs(range).." frames")
	elseif (range < 0) then
		self.selectionRangeText:SetValue(self.DeleteText.." "..math.abs(range).." frames")
	else
		self.selectionRangeText:SetValue(self.DefaultText)
	end
	moho:SetCurFrame(self.endFrame)
	mouseEvent.view:DrawMe()
	return true
end
function JL_time_tool:OnMouseUp(moho, mouseEvent)
	-- Go through the range
	local newStartFrame
	local newEndFrame
	-- if scrubbing backwards, let's start looping from the endframe instead and go forwards
	if (self.startFrame > self.endFrame) then
		newStartFrame = self.endFrame
		newEndFrame = self.startFrame
	else
		newStartFrame = self.startFrame
		newEndFrame = self.endFrame
	end
	-- go through each frame in the range and compensate the layer movement by the bone movement
	local frameAmount = newEndFrame-newStartFrame
	-- print ("moving frames by ", frameAmount)
	-- print ("top levels layers found: ", moho.document:CountLayers())
	moho.document:PrepMultiUndo(false)
	local layerList
	-- If going through only selected layers
	if not (self.editAllLayers) then
		for i = 0, moho.document:CountSelectedLayers()-1 do
			-- All contained group layers will be included automatically and selection doesn't affect there
			if (self:InsertTimeToLayer(moho, moho.document:GetSelectedLayer(i), self.startFrame, self.endFrame)) then
				modified = true
			end
		end
	else
		if (self:InsertTimeToGroupLayer(moho, moho.document, self.startFrame, self.endFrame)) then
			modified = true
		end
	end
	if (modified) then moho.document:SetDirty() end
	-- self.selectionRange:SetValue(0)
	moho:SetCurFrame(self.startFrame)
	-- moho:NewKeyframe(CHANNEL_LAYER_T)
	-- moho:UpdateSelectedChannels()
	-- moho.layer:UpdateCurFrame()
	moho:UpdateUI()
	return true
end
JL_time_tool.RANGE_CHANGED = MOHO.MSG_BASE
JL_time_tool.EDIT_ALL_LAYERS = MOHO.MSG_BASE+1
JL_time_tool.DefaultText = "Select time to insert/delete."
JL_time_tool.InsertText = "Inserting time"
JL_time_tool.DeleteText = "Deleting time"
-- First init before LoadPrefs starts to work
JL_time_tool.editAllLayers = true
function JL_time_tool:DoLayout(moho, layout)
	self.selectionRangeText = LM.GUI.DynamicText(self.DefaultText, 0)
	layout:AddChild(self.selectionRangeText)
	layout:AddPadding()
	layout:AddPadding()
	self.editAllLayersCheckbox = LM.GUI.CheckBox("Edit all layers", self.EDIT_ALL_LAYERS)
	self.editAllLayersCheckbox:SetValue(self.editAllLayers)
	layout:AddChild(self.editAllLayersCheckbox)
end
function JL_time_tool:HandleMessage(moho, view, msg)
	if (msg == self.EDIT_ALL_LAYERS) then
		self.editAllLayers = self.editAllLayersCheckbox:Value()
	end
end
function JL_time_tool:SavePrefs(prefs)
	prefs:SetBool("JL_time_tool.editAllLayers", self.editAllLayers)
end
function JL_time_tool:LoadPrefs(prefs)
	self.editAllLayers = prefs:GetBool("JL_time_tool.editAllLayers", JL_time_tool.editAllLayers)
end
function JL_time_tool:ResetPrefs(prefs)
end
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 5:28 pm
Try removing ALL undos, both multi and single, and put moho.document:PrepMultiUndo() as the first line in your OnMouseDown function.
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 5:33 pm
by lehtiniemi
synthsin75 wrote:Try removing ALL undos, both multi and single, and put moho.document:PrepMultiUndo() as the first line in your OnMouseDown function.
I have:
-Group layer
---- Vector layer
-Bone layer
-Vector layer
PrepMultiUndo() (both with true and false as parameter) produces only one undo step which undoes the keyframe changes only on the first group layer (but not layers in it).
Re: PrepMultiUndo()
Posted: Wed Mar 23, 2016 6:34 pm
I don't have the time to delve too deeply into troubleshooting an entire script, but here's my suggestion. Select each layer before making changes to it. See if that helps.
Re: PrepMultiUndo()
Posted: Thu Mar 24, 2016 6:01 am
by lehtiniemi
I understand. Thanks for your help anyway.
The craziest thing is that when I finally gave up on it and decided to only do just one
PrepUndo(nil)
at MouseDown, it works but of course it shouldn't. As a result of this, I get one undo step that undos every change on every layer I touch. (at least it looks that way). But PrepUndo(nil) is supposed to tell AS that no undo should be possible. Something's going south there, but it works now for some reason.
I have now posted the script for testing. It includes many of problems you guys helped me to solve. :) Thank you so much!
Re: PrepMultiUndo()
Posted: Thu Mar 24, 2016 8:34 am
I found that I have used PrepUndo(nil) on some older scripts of mine. I've never seen PrepUndo tell AS something is not undoable. So I think you found the right way to do it.
