Way to detect the active tool?
Posted: Sun Mar 06, 2016 12:04 pm
by lehtiniemi
Is there a way to detect the active tool?
I'm trying to find a way to detect which part of the layer the user wants to manipulate: bones or the layer translation. Both can coexist and I want to find a way to figure out automatically which one the user wants to animate. I was thinking that if the user has Transform layer -tool active, he/she wants to manipulate layer data. Same with bone tool -> bone data.
If detecting the active tool isn't possible, any other ideas how to determine which one the user is working on currently? Active tool would be the easiest to use as the source.
Re: Way to detect the active tool?
Posted: Sun Mar 06, 2016 12:51 pm
I can't think of any way to detect current tool, but you may be able to detect last keyframe added.
It would be messy, but you might be able to undo/redo to find which keyframe was added last. I think this would be awfully slow, for each keyframe in each channel, and you might even need to make multiple undos/redos (since undo can effect more than keyframes being added).
The only other way I can think of would require you modding all the AS tools to update a ScriptData variable when used. That would be hard to maintain though.
I don't think I'd want to tackle either option.
Posted: Sun Mar 06, 2016 3:15 pm
by lehtiniemi
Thanks! I guess I'll just split the script into two in that case, until I can find some way (or support for such detection arises in future versions)
Posted: Sun Mar 26, 2017 3:26 am
by JeroenKoffeman
In moho 12 it's possible:
ScriptInterface:CurrentTool()
http://mohoscripting.com/index.php?show ... ce&id=1227
Posted: Sun Mar 26, 2017 3:47 am
by lehtiniemi
JeroenKoffeman wrote:In moho 12 it's possible:
Oooh WOW! Thanks for the info! :))) this makes tool scripting much smarter and reduces the amount of scripts.
Posted: Sun Mar 26, 2017 12:26 pm
Thanks, Jeroen, I'd never seen that one.
