Cannot render and convert Jpeg/Png into vector
Posted: Thu Feb 25, 2016 12:22 am
by dongtime
I tried to export my animation but "compression setting" does not appear and my AS does nothing. I tried batch export my animation but all i get is a black screen file. When I convert jpeg/png into vector, my Anime Studio freezes as well
I'm using Anime Studio Pro 11.
Do you think the problem is because I'm using windows 10?
My friend who has windows8 doesn't encounter any problem
Or do I need to download a codec or someting? if its so, where can i find it. Please help me...
Re: Cannot render and convert Jpeg/Png into vector
Posted: Thu Feb 25, 2016 1:27 pm
by wizaerd
I cannot say as the specific issue you;re having, but I can say I'm using Windows 10 with no issues at all. So I don't believe it's an issue with the version of Windows, although it could be something specific to your version of Windows, as it's configured, or setup, or how it interacts with your hardware.
Posted: Sat Feb 27, 2016 1:44 am
It sounds like the whole video framework is missing on your system.
Do you have any video editing software on the same computer?
If so, does it export without problems? If not, missing codecs might be the problem. Re-install the video software (usually they've got all necessary codecs on board), or research which codecs should be installed with your Windows version.
Posted: Sun Feb 28, 2016 5:30 pm
by dongtime
slowtiger wrote:It sounds like the whole video framework is missing on your system.
I have Sony vegas and i can export a video with no problem. So i guess codecs is not the problem. Thanks for help.
wizaerd wrote:I cannot say as the specific issue you;re having, but I can say I'm using Windows 10 with no issues at all. So I don't believe it's an issue with the version of Windows, although it could be something specific to your version of Windows, as it's configured, or setup, or how it interacts with your hardware.
I think this might be the problem but i don't how to deal with it or fix it...
I'm using NVIDIA Geforce Experience + Windows 10. I already update it and still not fix. Got any advice or idea?
Posted: Sun Feb 28, 2016 8:49 pm
by wizaerd
I do seem to recall having an issue with NVidia Experience when I first got Windows 10... I believe running it as an Admin allowed it to run it's update... I also had to manually download an update to the NVidia Experience application before the automatic updates would work...
Posted: Mon Feb 29, 2016 12:57 am
by dongtime
wizaerd wrote:I do seem to recall having an issue with NVidia Experience when I first got Windows 10... I believe running it as an Admin allowed it to run it's update... I also had to manually download an update to the NVidia Experience application before the automatic updates would work...
I try reinstall and update both NVidia Experience and Anime Studio pro 11.2 with admin run and still same issue.
I also check and/or uncheck the GPU thingy in setting just in case but nothing change... Anybody got idea how to fix this?
