Paint bucket adding points
nina_paley
Post by nina_paley »
I'm drawing some shapes with maybe 20 points. I color them with the paint bucket and bam! suddenly they have 60 or more points. I undo, 20 points again. Paint bucket, bam! way more points. Can anyone tell me what's going on? Many thanks.
Re: Paint bucket adding points
The first question I'd ask is: Do I have several identical shapes on top of each other?
Hi, Nina.
The Paint bucket works in two ways:
- If the line is closed and simple, it will use the same points to create the shape
- If the shape you want to create is more complex and not welded, then the software will try to guess and trace it, creating more points.
nina_paley
The shapes were closed. It's weird, it only seemed to happen on one particular layer. When I re-drew the shapes on another layer, it worked fine.
Then the same thing seemed to happen on yet another layer. I must be doing something... Maybe I'm accidentally making extra shapes where I think there's only one? I'm still pretty new to ASP, so I often do things by accident without having any idea what the heck happened.
If you want, you can send me the file to take a look.
nina_paley
Víctor Paredes wrote:If you want, you can send me the file to take a look.
Done, check your email. Thanks!
lwaxana
Post by lwaxana »
Are you the Nina Paley of Sita Sings the Blues???
uncle808us
Post by uncle808us »
Don't keep the answer secret, :) I too have had this happen and I am following this thread.I'd like to know the answer if there is one.
http://uncle808s.blogspot.com
