Practical way to draw guide lines
Posted: Tue Jan 26, 2016 9:15 am
by rbrowngps
I am using Anime Studio Pro 10, and trying to draw useable guide lines (on a separate vector layer) to help me draw a character turn around.
I am drawing a straight line (using the add points tool and holding down shift), then selecting the points and clicking create shape.
This provides a straight line with a stroke of the width I have set, but when I go to another layer, the guide lines are very blurry, and guide lines with very small strokes are not even visible.
Is there a way to make the guide lines appear as they are drawn (not blurry) on all layers?
Is there a setting I am missing (I do not have any blur radius, motion blur or shadow options checked)?
Is there a better way?
Re: Practical way to draw guide lines
Posted: Tue Jan 26, 2016 9:53 am
I'm not exactly sure what's happening in your scene but you could try disabling GPU Acceleration and/or Antialiasing from under the Display Quality panel in the lower right side of the workspace. On my computer, GPU Acceleration tends to create a number of display issues so I usually leave it off. If you want to fully disable it, you should also disable the option for it in the Preferences panel.
You might also want to use a heavier line weight that won't get too thin when you zoom out because, AFAIK, you can't fix a constant line weight for different zoom levels. (If there is a way, hopefully somebody will correct me on that shortly.)
G.
Posted: Tue Jan 26, 2016 9:56 am
by hayasidist
yeah -- turn off GPU to lose the "blurry" look.
or use the built-in grid? View / Grid Settings ... then select "square" with a spacing to suit your needs?
Posted: Tue Jan 26, 2016 10:12 am
Yes, the Grid works well too. You may want to disable Grid Snapping if it's on because it can sometimes be a hindrance when setting up artwork. About the only time I like having Grid Snapping enabled is with I'm setting up SB Dials for a character.
Sometimes I wish we had guides we could drag onto the screen like the ones in Photoshop.
G.
Posted: Tue Jan 26, 2016 12:29 pm
by rbrowngps
Greenlaw wrote:I'm not exactly sure what's happening in your scene but you could try disabling GPU Acceleration and/or Antialiasing from under the Display Quality panel in the lower right side of the workspace. On my computer, GPU Acceleration tends to create a number of display issues so I usually leave it off. If you want to fully disable it, you should also disable the option for it in the Preferences panel.
G.
Turning off the GPU acceleration solved the blurry line problem; thank you.
Additionally, I am finding that when I draw a guide line with a stroke width of less than 5 the lines disappear randomly when I zoom.
I will try using the grid. Hopefully this disappearing guide line phenomenon will be fixed in a future release of the software.
