Hello.
I am learning Anime Studio Pro 11 on an iMac OSx 10.11.2 El Capitan.
I have opened up the character 'boy spikey' from the Character Wizard. When the character is displayed in the main window, I notice it is very fuzzy around the edges. - the lines are not crisp and sharp like they should be.
Can anyone suggest what might be causing this? - i have also just noticed it occurs when I draw shapes with the 'Draw Shapes' Tool. For example, if I draw two shapes, one shape has sharp edges, and the other one has fuzzy edges. When I select one of the shapes, it becomes sharp edged, and the other one becomes fuzzy edged.
Any advice very welcome.
Regards.
Unexplained fuzzy image.
Re: Unexplained fuzzy image.
Try going to the display quality and turn on antialiasing.
GPU acceleration works by rendering the content of unselected layers to display. It doesn't effect your final render, and if it bothers you, you can disable it in the display settings and/or preferences.
